The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
0 Members and 59 Guests are viewing this topic.
thngr
Quote from: T-1000 on January 10, 2015, 04:49:42 PM
Magnets in the center, iron buttons in rotor and coils outside?
iron buttons couse eddy currents; they have to be isolated steel laminations at least. they have to match magnets as equal numbers each. Despite all these conditions it works fine if you do not count a little drag while powering a light bulp.
gotoluc
shylo
Nice Rig MCR, When you short the coil it is continuous right? If you made a switch so the coil only shorts at max output, and feed that through a bridge into a cap bank, then back to supply I think your input will be reduced.
Looking forward to more vids.
Thanks artv
T-1000
Quote from: Mister Caribbean Roots on January 10, 2015, 09:42:24 PM
Just playing around with a 8 & a 12 pole rotor on this flux gate setup... 8)
Hi,
In your setup the induced magnetic field in coil (Lenz force)  is still against movement...
Can you try to get static NS magnets and rotor (with ~2mm depth laminated transformer steel pieces on it and the length should cover the gap between N and S poles of magnets) between stationary coil (between N/S poles of magnets) and stationary magnets then repeat experiment?
Cheers!
ramset
Thanks Grandma
