The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
0 Members and 72 Guests are viewing this topic.
Abt
Hi MCR,
thank you for the reply. So I obviously misunderstood somthing :-\
However, doesn't matter.
Here is one of my older vids for you:https://www.youtube.com/watch?v=5szHAMUAzI8
It was made for a different forum and so I did not explain much as we were talking about it in the forum, the Ampmeter is a wee bit hard to see.
You see an Adams motor with high inductive coils, I drive it with 230 V from the grid. @ 130 mA as you can (hopefully) see.
DC, so one can messure properly. You can see a 15W lightbulb, it's running @ 235 V on the back puls power, so this is really 15W for sure. The motor drives a small stepper motor as a generator, 20 W halogen bulb @12,5 V (which is at least very close to full
power). When I connect the second light, the voltage drops too much, so I can't get the output any higher, but I would say, I'm at least very close to unity if not slightly above.
A good thing about this Adams motor is, as you can see, selfstarting. The magnets are very strong and will always keep the rotor
in perfect position. Diameter of the rotor is around 240 mm, some torque!
regards
Abt
thngr
Aren't we trying to inverse dragging lenz effect to pulling forward lenz effect by stationary magnets and coils? Nothing new but ENERGY! Do not move out from the subject.
simple logic is two men at sides pulling you in at the same time but when you are at alignment with those two and one disappears other man can not be able to stop you.( two men were magnet and the coil you pass current in while to generate electricity it would be come elekromagnet. From the alignment one man or coil collapses on it's own and you (I mean our ambassador(iron pieces)) go to your way freely :D  )
pic to think: http://overunity.com/15083/the-new-generator-no-effect-counter-b-emf-part-2-selfrunning/dlattach/attach/146177/
T-1000
The iron core passes free through magnet as it was shown in Grum build. All It needs - that balance around circle of rotor so net magnetic forces are zero on rotor. And the induced magnetic field on coils (Lenz) is isolated from rotor spin angle. So all you need is precise engineering to run it like clock where all losses are minimized.. :)
Cheers!
thngr
this gif is for understanding the effect but I couldn't drow the lamp and serial diode on it to show when it is on or force vectors too much time to do.(red matter is magnetic core :)
prochiro
All
Maybe some here should look at the end of the second film of the two given to us where he goes into the house and shows a cad of his generator.
You will notice that as a four pole generator, the deflectors are as big as the magnets. Each deflector is covering many coils.
The basic design on this film is a bar magnet with an equal sized iron and many coils being fed by each iron.
Prochiro
