wheel-idea
Started by Dellemann, September 15, 2006, 04:30:55 PM
FreeEnergy
the trick here is the shifting of the balls within the wheel making the wheel imbalanced. still you would have to built it and see.
ResinRat2
I think it has potential. The right side can be extended as much as needed to get the leverage to lift the three other balls. Also the ball is rolling downhill most of the time until it again gets close to the axle (fulcrum) point. Very clever!
Gregory
Hello,
Good looking design, it is a variation of the original. I guess it won't work, but it can be tested in WM2d.
I see one problem with this, and every similar deflector track type design (in this way).
The force caused by the weight in the gravity field act on two bodies. One is the spoke of the wheel, and the other is the deflector movement track. So, the force produced by the weights divided into to parts, act on the wheel, and on the track at the same time. Therefore this wheel always use the force of the weights partly on a useless way.
I checked the animation step by step, and I think it has equilibrium points, and won't work, but of course it's hard to tell for sure by sight only, especially in this way the weel operates.
Before anybody decided to build, I recommend to do a simulation first.
Principle: It's always easier to thrust a car up on a slope, than to lift it up (when it is hanging in the air).
A published invention from a ,now dead, german inventor:
DE3621312,Gravitator: a water-wheel/pump-concept
Can somebody simulate the process ?
Sincerely
            Lanca
Dellemann
hello to all,
thanks for your repley.
I make some drawings with 16 weights (red) and the weights are never in balance.
On the right side (down side)  the sum of the distance to the middle is approxemately 1,6 x higher then the left side sum disdance.
(I don't know the word in Englisch "Schwerpunkt)
So the problem is how Greg&Gregor said ""a car on ramp or free hanging is different""
OR the friction is the problem. I had download the sim-program WM but it dosen't work on my computer.
Lanca: thanks for the info about the patent but the pump need also energy !!!
