Selfrunning Free Energy Permanent Magnet Motor - The Simon Magnet Motor motor
Started by hartiberlin, December 04, 2014, 01:35:19 PM
tiquila77
No, it wont operate the same if all
the ring magnets were stationary
and the rotor was comprised of
only the angled magnets.
The angled magnets function like wave guides; besides, a closer look at the magnetic flux of the motor would reveal that if the angled magnets were to function as the rotor, the net torque acting on them would be small.
The maximum net torque would be obtained when the rotor comprises either the middle ring magnet or the the other two ring magnets and the inclined magnets, or the middle ring magnet and the inclined magnets.
hartiberlin
Please vote for the Simon Motor now called:
Inexhaustible Power Source (IPS)
http://contest.techbriefs.com/2016/entries/sustainable-technologies/6313
Many thanks.
Regards, Stefan.
P.S. You first have to freely register and login into this website to vote.
hartiberlin
Okay, here are some important news I received from Simon regarding his motor:
Stefan,
As a matter of fact, my design will surely work. You'd recall that I once told you about a German professor that picked interest in my design. You'd also that I said he built a modified version of the motor, and the prototype didn't work.
Now, after having perfected my understanding of how to rightly use ANSYS Maxwell, I simulated the two modified versions that he built; the software confirmed the behaviour of the prototypes. The software confirmed the extremely high cogging torque and the extremely short deceleration time.
Here's the sweet part. The software revealed that for the prototype to work, the rotor magnets should be reduced to either 40, or 30, or 20, or 10, etc. (Note, his prototype has 50 rotor magnets.) The software also revealed that the net forward and net back magnetomotive forces(mmfs) of the prototype are heavily dependent on the airgap lengths between the rotor magnets.
That is, there are particular airgap lengths that would cause the forward mmf to be greater than the back mmf; and there are particular airgap lengths that would cause the back mmf to be greater than the forward mmf. And there are particular airgap lengths that would cause the forward and back mmfs to be equal in magnitude and thus produce zero torque and zero rotation.
Currently the professor isn't carrying me along; he doesn't tell me things anymore. When I asked him why he hasn't reduced the rotor magnets to either 50,or 40, or 30, or 20, or 18, 16, etc; he said that he used glue to hold the magnets in the rotor frame, and that removing them would damage the magnets.
Regards,
Simon
The attached document contain the simulation results and the model used in the simulation.
FIGURES 2 to 7 show the simulation results which confirm the behaviour of the prototypes built by the professor.
FIGURES 8 to 11 show the only ways the prototype would work.
FIGURES 2A to 2C show the nature of the output torque, the speed, and the solid loss.
FIGURES 3A to 3C show the the deceleration of the rotor when given a push of 300rpm in the clockwise direction. As shown, the rotor comes to rest in less than a second.
FIGURES 4A to 4C show the deceleration of the rotor when given a push of 300rpm in the counterclockwise direction. As shown, irrespective of the direction of push, the rotor always comes to rest in in less than than a second. The professor said it was like the rotor was in a viscous fluid.
According to the professor, the same thing happened when he used 25 pcs of NdFeB magnets as the rotor magnets. FIGURES 5A to 5C confirm the results. And FIGURES 6 through 7 show the effect of giving the rotor a push  in the clockwise and counterclockwise directions.
Regards,
Simon
Dear Stefan,
Cogging/detent torque is defined as the tendency of the rotor pole to align with the stator pole at minimum reluctance position. Pages 812 to 813 of the Ansys Maxwell's manual explain how to use the software to calculate cogging torques. I've calculated the cogging torques of the motor when 50, 40, and 25 oblique magnets are used. The attached pictures are the results.
FIGURES 1A shows the result when a steel-1008-ring rotor and a 25-oblique-magnets stator are used.
FIGURE 1B shows the result when a 25-oblique-magnets rotor and a steel-1008-ring stator are used.
FIGURE 2A shows the result when a steel-1008-ring rotor and a 50-oblique-magnets stator are used.
FIGURE 2B shows the results when a 50-oblique-magnets rotor and a steel-1008-ring stator are used.
FIGURE 3A shows the result when a 40-oblique-magnets rotor and a ferrite-ring stator are used.
FIGURE 3B shows the result when a 40-oblique-magnets rotor and a steel-1008-ring stator are used.
FIGURES 1A-1B and 2A-2B show that the cogging torques are acting both in the clockwise and counterclockwise directions, meaning that the torques would resist any attempt of the rotor to spin. This is the reason the rotor behaves as though it were in a viscous fluid.
The graphs also show that the induced magnetic poles in the steel-1008 ring are roughly aligned with the poles of the oblique magnets.
The reason I use the word "roughly" is because of the fact that the graph plots are slightly towards the negative torque-axis. One effect of this rough magnetic locking is the slight difference in deceleration times of the rotor when it is given a push in the clockwise and counterclockwise directions.
FIGURE 3A-3B show that the cogging torques are unidirectional. The graphs also show that the induced magnetic poles in the steel-1008 ring are not aligned with the magnetic poles of the oblique magnets, i.e. there's no magnetic locking. Each time the magnetic poles of the oblique magnets attempt to lock on to the induced poles, the induced poles move away in the direction of rotation. As long as there's no magnetic locking, the oblique magnets will rotate continuously about the axis of rotation.
The pdf document contains information on the simulation results of the motor when 10,11, 12, 13, ...50 oblique magnets were used as the rotor.
I have the CAD file of the invention for 3D printing. Just in case you find anyone that would be interested in building the prototype.
Regards,
Simon
Be sure to View the 2 PDF Files , as they contain also all pictures !
hartiberlin
hartiberlin
