Centrifugal gravity wheel
Started by inroades, September 20, 2006, 06:30:17 PM
inroades
   Hello Stefan
    The idea is that the wheel will not work until it gets up to an rpm where centrifugal force overcomes gravity enough to lift the 12 o'clock weights rapidly into the stationery angled upper ramp where it converts the additional centrifugal force to rotory power in the wheel and the weight latches there in the outer position all the way down the power side to the 6 o'clock position.   At the bottom 6 o'clock position the weight is released again, basically slung towards the lower spring ramp. (kind of the David/Goliath sling effect) The weight stores a much greater force than its own mass in the lower spring, but the spring only has to return the mass of the weight. I was using the tennis ball to replicate the effect of the spring only.  My wife shot this video with our phone so it is not too good, I promised you crude and it is(fat guy chasing a ball) ;D. In the video it looks like I am throwing the ball but I am holding it between my thumb and finger and just letting go.
     I will work on a better drawing today.
   Thanks for your interest.
    Dale
There is no limit to what a man can do or where he can go if he doesn't mind who gets the credit.
inroades
 Here is a picture I made in paint.
   Thanks
FreeEnergy
Quote from: inroades on September 23, 2006, 03:56:13 PM
   Thanks
this picture answers a lot of questions! nice job.
it is like hartiberlin  has been saying for a long time now, to use springs.
hartiberlin
Hi Dale,
thanks for posting the video and the new painting.
Looks promising.
Maybe can you try it with heavier balls ?
Maybe with steel balls or with a non compressable ball ?
hartiberlin
Dale,
another question,
do you let go the weights just at 6 o?clock
and then they just slam into the ramp,
are then reflected by the spring and then lock again
nearer to the axis ?
This is an interesting idea !
But you have to make sure,
that the speed will not get slower, so if you release the weights at
12 o?clock and they fly out again, that they are able to hold the speed
of the wheel and don?t slow it down.
But when they are locked then again at the outer position, okay,
they have a bigger lever arm and then are able to turn the wheel
counterclockwise.
