Generator by Gerard Morin
Started by d3x0r, December 15, 2014, 04:34:16 AM
tesletic
Quote from: TinselKoala on October 14, 2015, 09:13:08 PM
Asked, and answered several times already. He is not using appropriate equipment or procedures, he is making claims unsupported by actual evidence and he isn't performing actual true experiments. He continually confounds units of power and energy, he misuses the equipment he does have and he clearly doesn't understand his own setups.
Anybody can multiply two numbers together and get some answer that is _mathematically correct_. But if the numbers are garbage "data" to begin with, the result of the math is also meaningless garbage, even if it might be mathematically correct. And that is the case with Morin.
Thanks for proving I was right !  ;D ...you figure it out ! LOL
" THE PERSON WHO SAYS IT CANNOT BE DONE SHOULD NOT INTERRUPT THE PERSON DOING IT ! " 8)
fritz
Hi !
Have not been here for I while, I clicked on the first thread (this one), watched the video, finally skipping to the last comments on this thread (to be honest).
I´ve never seen such a dog-and-pony show here before - and the only overunity here is the self-confidence of the demonstrator.
I can just underline every single statement of TK, just wondering why he is spending part of his lifetime commenting this.
Explaining all effects, misconceptions, errors, assumptions might take lots of hours - including basic fundamentals of all involved parts he is using.
To keep it simple - his lossy motor-generator setup transforms a DC voltage source (batteries) into somewhat high frequency AC current source (Generator has higher idle voltage, inductivity and source resistance).
In combination with lots of different nonlinear loads designed for different voltages and frequencies, using internal regulators (fluorescent ballast or LED drivers) - you can observe what happens.
I skipped all "measurements" and and calculations - because the setups and the used equipment is so wrong to get a clue what is going on here.
A simple test with a linear load resistor+calorimetry (so we can skip expensive RMS meters (does he know what that means ?)) and proper DC input power measurement would prove that there is nothing interesting going on here.
If I would do lectures at a technical college, I could use this video for an exam. "List all misconceptions, measurement errors, wrong assumptions". Would be perfect.
scratchrobot
For all you idiots out there, you just have to shake your head a little bit because sometimes things can get stuck up there.
This guy is a my new favourite comedian, i like the video where he has the nutty professor confirming seeing the flow of the electrons, you can't see it on camera but with the naked eye you can see things moving at light speed.
Amazing how he get energy out of a pump, yes it's not a generatator but a pump and the energy is building up, he measured the amps with his geiger counter and you can see that the output is 4000x more than the input.
Nice demonstration of using Tesla technology and quantum physics to extract electrons from dark matter!
Can't get enough of this  :)
https://www.youtube.com/watch?v=Ydvic9aG5BE
Bob you like to stick your finger between the two wires.. haha
fritz
Quote from: scratchrobot on October 15, 2015, 06:02:13 AM
"we call it now "the pump""
"because it is more energy than volts"
"This transformer makes 65.000 (!!) volts - because its from a ozon thing and you need more than 50.000 volts to get ozone" yup. pure nonsense.
"This is a closed loop Geiger counter"
"26Amps" Maybe his Geiger counter is not used to something else than 60Hz ?
"The flow of electrons"
Another vid:
Teslas Secret Finally Understood
https://www.youtube.com/watch?v=YZ7I9XgaW3A
"its no longer ac current - its radio frequency" wow.
OMG.
Definitely experts in their field. ;D
scratchrobot
What more proof do you need? The numbers speak for them self.
This one is self running and charges the battery and is powering a light on top of it!
It doesn't matter volts or amps is all the same, this thing is amazing, can you imagine running this at 10.000 rpm  ;D
https://www.youtube.com/watch?v=aOLnf_gP7K8
