Generator by Gerard Morin
Started by d3x0r, December 15, 2014, 04:34:16 AM
tinman
Quote from: memoryman on January 21, 2016, 06:11:55 PM
Yes, I did. Where is the extended self looping?
Indeed ;)
Teslatic may not know the difference between surface charge and deep charge in a battery :D
Remove the circuit,and run the two lights straight from the two batteries hooked in parallel.
I bet the battery voltage dose the exact same thing--drains the surface charge of,then settles on a voltage that remains quite steady for some time driving those lights.
Brad
Meta
Quote from: memoryman on April 25, 2016, 09:16:49 AM
"And the "measurers" will scream....we cant measure it so it cant be real!!!!"
There are no DEMONSTRATIONS to show that it is real, only videos.
See? Here we have a measurer, already, screaming.
Well Sir, theres coming, a time when your instruments will not measure what is going on.
What will you scream then?
memoryman
There was no screaming. You can get medical help for your hallucinations.
If you can't measure it or even observe it, how can you know that it exists (outside your imagination)?
Meta
Quote from: memoryman on April 25, 2016, 01:32:28 PM
Albert Einstein > Quotes >
  "Imagination is more important than knowledge. For knowledge is limited to all we now know and understand, while imagination embraces the entire world, and all there ever will be to know and understand."
Now, memoryman, use your memory and re.member what I told you previously about the 2 sided universe. I said DNA is dual, the I Ching is dual, the Mayan Calendar is dual, your brain is dual and reality, the Mind, has a daul partner, the Actuality: Matter, and the seen has an unseen half. Many overunity machines are dual halves of each other. I told you 3 + 4th dimensions need a dual 5th, 6th, 7th and 8th. You didnt pay attention. You are an expert in Matter and Physics measurements using your one sense, rationality and logic and I am expert in Metaphysics using my Intuition or Imagination. Actually I use both rationality and intuition but you say
"If you can't measure it or even observe it, how can you know that it exists (outside your imagination)?"
I know by all that Ive studied about 2...and I used my imagination to image the universe...thats how. Since you only use 1/2 of your brain, never considering imagination or intuition, I would say you are a half-wit. I suggest you argue with Einstein.
By the way, Einstein was a half-wit also. He said matter twists, warps and spindles space, when it is space, the superior force that twists, warps and spindles matter.
memoryman
Regardless of all that, can you DEMONSTRATE even ONE OU device?
