Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
i_ron
Quote from: tinman on August 09, 2016, 07:25:16 PM
Nice video Ron,but fact is,many here have been using coils in this manor for years,and the zero force motor is nothing special,and uses the coils magnetic field in the very same way a PM DC motor dose,and has been doing for over 50 years--but fun to mess around with.
Brad
Thanks Brad,  just working towards a working model, so nice to understand what it is that is taking place before I commit to metal and plastic.
Ron
tinman
Quote from: i_ron on August 09, 2016, 09:07:21 PM
Ron
One thing to remember,the center of either a PM or an electromagnet that some mistakenly refer to as the blotch wall,and being the neutral or weakest part or area of weakest magnetic field strenght,is actually not a blotch wall ,and is actually the point of the greatest field strength,which includes the greatest electric field where an electromagnet is concerned.
Brad
minnie
   How can one delay or alter that which is instantaneous?
                John.
tinman
Quote from: minnie on August 10, 2016, 04:09:50 AM
                John.
Nothing is delayed.
!Delaying Lenz! as they say,is not what is happening with the !speed up under load! saga.
This !speed up under load! is a misconception.
The load is already on the rotor as soon as the coil and core material is present/or in position to that of the rotor. When a load is placed on the generating coil,eddy currents that are already flowing within the coil and core material,are some what !relieved! you might say. So the load on the rotor when the coil is open,is the generation of eddy currents and that results in heat. You place a load on the coil,and the eddy current value is reduced,and there for the waste heat is also reduced-->you are turning waste heat into electrical energy when you place a load on the coil.
There is no magic in the !speed up under load! effect-->this also applies to air core coils of low inductance values.
Brad
allcanadian
@tinman
QuoteOne thing to remember,the center of either a PM or an electromagnet that some mistakenly refer to as the blotch wall,and being the neutral or weakest part or area of weakest magnetic field strenght,is actually not a blotch wall ,and is actually the point of the greatest field strength,which includes the greatest electric field where an electromagnet is concerned.
Actually no, as I have measured and mapped the magnetic fields with sensitive hall effect magnetometer arrays which prove otherwise. We could ask a simple question, when two opposite conditions come together what do you get... ambient conditions. Not unlike positive and negative charge coming together to negate each others external field, not unlike a positive air pressure and a negative air pressure mixing to become no air pressure. I'm really not sure how anything could be more blatantly obvious because we see these effects all around us everywhere every single minute of every day.
Do you have proof to justify your obviously false claim?.
AC
