Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
0 Members and 28 Guests are viewing this topic.
BorisKrabow
I'm sorry to see a lot of people disappointed in free energy. and therefore they consider it normal to violate the norms of behavior.
BorisKrabow
   Hi  kolbacict  ,  These are externally similar, but different in technology devices. The author accidentally stumbled upon a new effect. Romero was very close to it.
BorisKrabow
for those who are disappointed in free energy, I will try to give an opportunity to return this faith .
               The simplest description of Reverse Lenz .    If the electrical circuit is closed, then when approaching the magnet and the coil have the same poles, and when moving away from each other, the coil and magnet have opposite poles .thus obeying the Lenz rule Rotor is braking .
               If the magnetic field in the coil decreases when a magnet approaches it , with a certain arrangement of magnetic poles .
The coil changes its properties to the opposite . rotor starts to accelerate .
               I think advanced readers will immediately understand what I mean.   :)   :) .
If everything is perfect from the point of view of theory, then
The next step is technological research and implementation in a real device.
     the pictures shown are an example of options and search directions.
BorisKrabow
hi all !   I have interesting news . I was able to detect   effect Lenz reversal   . The idea that I posted a few years ago turned out to be working   :)  .  Of course, there is a possibility of inaccuracies in measurements and incorrect interpretation of the processes in this strange device.  But let's get to the test .
             The figure ( Reverse_Lenz_15 ) shows a device having an air coil . A plate made of transformer steel is installed on the coil . A stator magnet is mounted against the coil.  The rotor magnet acts on the steel plate with the opposite pole from the stator magnet.
             With the same movements of the rotor magnet, the electric current in the coil changes to the opposite ,  depending on whether there is a stator magnet or not . Since the direction of the current in the coil is inextricably linked with the location of the poles of this coil ,   when the current changes to the opposite, the magnetic field of the coil (Lenz) begins to contribute to the movement of the rotor magnet.
               This phenomenon suggests that we are dealing with the manifestation of free energy.
   The figure ( Reverse_Lenz_16 ) shows the device described above . I will try to add more information later.
    I hope this test will attract the attention of researchers who will repeat it and go further than I could.
   Best regards
    Boris
activ25
You can modelize your device with the software FEMM, it is 2D but it is very acurate.
