Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
0 Members and 23 Guests are viewing this topic.
hoptoad
Quote from: shylo on August 31, 2016, 05:02:20 AM
snip....
    one set-up was strange though and am trying to build it again , I would fire the coils for drive only for an instant and 180 deg. later the coils were giving a big kick to the rotation , a much bigger kick than the original dump.
It's like the coils themselves were acting like caps somehow.
Interesting effect.
I like to see the work of others sometimes it helps.
Thanks to all who contribute.
artv
Yes, I like to see the work of others too. Like most here, I suffer from severe curiosity.  :)  An ailment I'm happy to bear. ;)
tinman
Quote from: Erfinder on August 31, 2016, 08:58:35 AM
The ignore function works, just wanted to share that in case anyone felt the need to use it, I just added two individuals.  Felt good.....
Ah,i see.
Was to be expected-and was as predicted.
Lets hope those here do not choose to ignore those who have given freely-and will continue to do so.
Brad
Dog-One
Quote from: ErfinderAction and reaction are not sequential, they are not equal opposite, they are simultaneous-sequential, they are asymmetrical.
See, you do these things to us that make our heads hurt based on our learned definition of each word.
I get the concept, only because it came from you, but from anyone else, I would say to them, you're full of shit.  You can't be "at the same time" AND "in sequence".  Sequence infers order as in first, last.  Simultaneous infers exactly together in lock-step.
There has to be some words out there in the vast Aether that better describe this concept.  Something like cause and effect linkage, a recursive concept.  A condition where the cause comes from the effect as well as the effect coming from the cause.  An unbreakable bond of two distinct components that cannot be observed as anything but a singularity.
shylo
So when motoring , generation is happening, and when generating, motoring is happening?
The problem is they cancel, unless you can switch the operations on and off at the right times.
I've seen where you dump one cap bank for drive and makes another bank collecting generation jump by 30 percent.
Lenz is part of the function , no way around it that I can see, just need to design the system to take advantage of Lenz instead of eliminating it.
It has all to do with magnetic fields, the more fields you add , the more complicated it gets.
One field acts one way, Two fields act another , now add several ,whole new ball game.
I think everything is a result of interacting magnetic fields, the more the merrier.
artv
web000x
@Erfinder,
Did you build a Transforming Generator replica?  The reason I ask is because I'm looking into Jim Murray's SERPS concept and I'd like to know as much about the the T.G. as possible.  I was speaking with another forum member and they suggested that you may have built one.   If so, do you have some youtube video links of any significant findings?
Thanks,
Dave
[size=78%]
[/size]
