Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
EMJunkie
Quote from: tinman on September 05, 2016, 05:47:25 AM
Much the same thing.
I can cut out the areas within the red boxes,other than that,if we have a diametricall magnetized magnet rotating inside the core,we have our dial gauge magnetic base. If you remove the two coils,the core either side of the coils will act just as the dial gauge magnetic base dose.
There is no need for the alloy cast,as that would only add drag ,due to the production of eddy currents.
Brad
Exactly, run and test, then cut later if needed, thats exactly right. I wanted to be clear for others. I knew you would know all about this.
Go Infinity Go!!! Well done guys!
https://www.youtube.com/watch?v=nAPPMU9E5DY
https://www.youtube.com/watch?v=y2iehK0Jez4
   Chris Sykes
       hyiq.org
tinman
Well thats interesting  :o
Video up soon.
Brad
tinman
Ok,well by doing what i did in the video,i would have thought two things would have happened.
The magnet being used is a N52 3/4 x 1" neo.
Power being supplied to the primary coil is of a very small value.
1st,i would have thought by placing this powerful magnet within the core center,would have saturated the core -or near too,and reduced the output on the secondary.
2nd,i would have expected a large biasing offset on the output wave form.
But as you can see in the video,we had the opposite effect in both cases.
https://www.youtube.com/watch?v=RIAQvvfAE0M
Brad
citfta
Thanks for the video Brad.  I was waiting for you to turn the magnet the other way so that it was horizontal to see what that would do to the power out.  By horizontal I mean so the ends would be at 9 o'clock and 3 o'clock.  You certainly do quick work.
tinman
Quote from: citfta on September 05, 2016, 08:59:19 AM
Oh yea-i should have done that.
I will go and do it now,and post some scope captures for you.
Brad
