Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
QuoteI was reading your quote on MH. I don't want to spend too much energy in a defensive statement, but consider that in his teaching he didn't even mention any vector or speed of motion that mechanicly causes the flux change. This way he does not only miss the whole point of this discussion, but reveals a severe lack of understanding in the field of induction. So this may be worse than I thought. I don't want to insult the guy, this is just a conclusion.
The remedial debating team strikes again.  All that I ask is that if you want to consider alternative explanations for things is that you also look at what established science has to offer.  We have the technology, we have figured out how a current-carrying wire interacts with a magnetic field.  Just remember that among the blind, the one-eyed man is king.
life is illusion
Ok guys, I did the test and I have to say that I was wrong and it doesn't work the way I was thinking it would. I'm sorry for wasting your times... Well, at least now I know that this design doesn't work and why...
Thanks to all of those who participated in this conversation :)
Best Regards
Sam
dieter
BorisKrabow
Hi All !  I accidentally found a russian document about Lorentz .
     RUS  : Так, если изменение магнитного потока вызвано изменением площади контура
(например, за счёт движения одной из сторон прямоугольного контура),
то индукционный ток возбуждается силой Лоренца,
действующей на электроны перемещаемого проводника в
постоянном магнитном поле.
Если же изменение магнитного потока связано с изменением величины внешнего магнитного поля,
то индукционный ток возбуждается вихревым электрическим полем,
появляющимся при изменении магнитного поля.
    translate.google.com
  EN  :  Thus, if the change caused by the change of the magnetic flux loop area
  (eg, due to movement of one of the sides of a rectangular circuit)
  then the induced current is excited by the Lorentz force,
  acting on the electrons move in a conductor
  constant magnetic field.
  If the magnetic flux change due to the change of the external magnetic field,
  then the induced current is excited vortex electric field,
appearing when the magnetic field.
           yup! That is why the  window generator overunity ......   on coils Lorenz and Lenz proceeds
     Vortical current  in the core axis
life is illusion
Quote from: dieter on December 30, 2014, 12:46:36 PM
What exactly happened?
Peace
Well, it seems like I forgot one of the first law of electromagnetic induction. The wire must move 90 degrees and vertically toward the magnetic field not align with the magnetic filed. In the pic you can see that the side of solenoid with green circle around it is responsible for generating electricity and it is divided to tow sides:  The red and the pink circle. These two are in opposite magnetic fields and what ever they generate will be canceled by the other one, thus no current will flow through the solenoid... And I also did a test and no current was generated which made me kind of sad but its always good to find out ones mistakes ;) But this doesn't mean we can't get around Lenz's law. This was just one of the ideas, there are many more. I'm working on one right now ^_^
Best Regards
Sam
