Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
EMJunkie
To give some more insight, and Brad may wish to add or interject if he sees this a bit different, but if we look at a standard Transformer and add an adjustable load...
Slowly increase the Load, or decrease the Load Resistance, and measure the Input Voltage and Current.
What you will see is a slow change in the Voltage to Current Phase Angle. This Angle will start off at maybe 75 Degrees or more 85 Degrees...
As you slowly increase the Load this will close, 70, 65, 55, 50, 45, 40, 35, 30, 25, 20.... Until the core becomes saturated and or Electrical Break Down occurs.
So, what does this mean, what are we seeing? Yes, the total Inductance is being reduced by means of Magnetic Field in the region of the Coil. As the Inductance is lost, the Coil becomes more and more like a Resistor. Current keeps going up and up, as the Reactive part of the Impedance (Z), is lost.
Now, the point, we see a Reactive Power component on the Input at 90 Degrees, this is where the Input Coil sees no real Load, the Load is entirely Counter Balanced if you like. For example: 1 + -1 = 0
Or as above:  5Kg + -5Kg = 0Kg
So the Input does not have too much or any real work because there is a Counter Balancing of Total overall Forces.
I hope this helps some! All experiments are very easily verifiable and provable on the bench!
Today, we see a very detailed description of how to use Lenz's Law to our advantage!
We even had an example!!!
COP: 4.249 thanks to Partzman's excellent work!!!
   Chris Sykes
       hyiq.org
i_ron
Quote from: EMJunkie on September 06, 2016, 11:17:19 PM
Hi Ron - Videos/Channel removed?
This the same by the looks: https://www.youtube.com/watch?v=yw0FA6JJ0BQ
   Chris Sykes
       hyiq.org
Sorry, I got the cart before the horse there, I had sarted near the beginning and thought it would lead up to the present.
Surprise for me... the whole thing ended in 2010
Which leaves a mystery... did it work??? why did it end???
http://overunity.com/8852/lafonte-group-can-turn-off-permanent-magnet-without-work/195/#.V9Ap3csrJpQ
But it was the mag base concept for sure
Ron
EMJunkie
Quote from: i_ron on September 07, 2016, 11:00:08 AM
Ron
Hi Ron,
Most all people don't have a lot of time, most don't have a lot of patience, most are easily worn down by small things...
Everyone has their own path, we see much interest at the beginning of the thread, then it runs down and we see that it appears as if we are wasting our time. Even though a thread may have a lot of reads, we see no real progress as we don't see what others are doing.
A lot of people keep their work secret.
A lot want to take others work and profit from it. Or take the credit for others work.
This, subjects of interest, come and go like the seasons, Change must come slowly and steadily.
But there must be stamina and patience, for things are easily lost without these quality's!!!
   Chris Sykes
       hyiq.org
shylo
When I'm using a solid steel rotor for my pm's it changes the effects I get when using separated pieces of steel as the rotor, Not talking about out-put , how the fields mix together.
Electrical flow is nothing , It's how the fields work together, Electricity is just a by-product.
artv
EMJunkie
Quote from: shylo on September 07, 2016, 06:35:05 PM
artv
Hey ArtV,
This is exactly right, Magnetic Field Interactions are important to see and understand.
   Chris Sykes
       hyiq.org
