Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
tinman
So many guru's
So few working devices
Brad
EMJunkie
BarBozo - Your filthy Drivel is just ridiculous! Compensating for something are we?
I am very familiar with Electrostatics and also Electrodynamics, in fact, perhaps more familiar than you may ever realise!
In all of Electrodynamics, Velocity (V) is defined as part of the Dynamical Formula's relative to Time (t) - The sooner you realise this, the less stupid you will look!
In the image you posted, to which you refer to, if the Charged Particles are moving concentrically around the common central point with Velocity (V) over the Course of Time (t) then we will see Field's, both Electric (Red) and Magnetic (Green) - But there is no indication of a Dynamic System, in the Image you posted, as I already pointed out!!! Which means it's Static, and Wrong!
Below I show the work of another, 1878 is the date of publication, a very well-known Author: James Clerk Maxwell - A Treatise on Electricity and Magnetism - Notice the very clear indications of a Electrodynamic System! EG: "Circular Current"
This may be worth a bit more than your "Scroll Down To" rubbish! You're completely full of Rubbish! Tesla studied the work of others, one being the works of Maxwell, let's not forget that! Yes Tesla was a brilliant Man, but a Man he was. You take Tesla's work completely out of context and make wild assumptions on it, clearly not understanding most all of it!
Thus the Air Core 50Hz 10KVA Transformer that you and Erfinder worked on, it will fail because of your miss-understandings of Tesla's work.
You assume far too much and gamble on bad bets! Thus you're strange Post with bad spelling and words put out of context.
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: tinman on September 19, 2016, 12:56:19 AM
So many guru's
Brad
Yes, we humans are stuck in our destructive ways aren't we!
We don't care for each other the way we should, after all we are all brothers and sisters! Maybe that's the problem, sibling rivalry, bickering between siblings.
   Chris Sykes
       hyiq.org
EMJunkie
Dear Barbosi - See Image for the Electrodynamic version of your Image:
   Chris Sykes
       hyiq.org
shylo
Hi Chris, I'm assuming that field pattern is when the coil is being pulsed with a power supply.
What will the pattern look like when being induced by a single magnetic rotor of all the same field,
the magnets being spaced so one is reaching the coil as the other is leaving the coil?
artv
