Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
0 Members and 74 Guests are viewing this topic.
i_ron
Quote from: citfta on September 25, 2016, 04:28:14 PM
I am going to stick my neck way out here and probably get it cut off.  But I think this may be part of what Erfinder is trying to get us to see.  If you look at the attached circuit you will see that as you pulse the transformer one of the secondary windings is shorted.  When the pulse is removed the short is also removed allowing the collapsing magnetic field to charge the cap through the bridge I have across the other secondary winding.  The transformer is a standard 120 volt primary with a tapped secondary with an output of 12-0-12.  The interesting thing is with the coil shorting technique I can pulse the primary with only 12 volts and charge the cap to over 12 volts.  There should have been only 1.2 volts going to the cap.  But pulses do strange things with transformers.  And shorting one of the secondaries does even more strange things.
Build this circuit and try it both when shorting the secondary and without shorting the secondary.  See what you get.  You can use whatever you want to control the transistors but I have included a simple 555 timer circuit if you don't have a function generator or microprocessor to give you the pulses.
Thanks for taking that chance Carroll, that looks liken interesting lead, lets hope erfinder will comment.
Normally I would jump right in but I am working on a new rotor design for the Ward thing, so otherwise occupied.
Ron
citfta
Quote from: Erfinder on September 26, 2016, 01:26:43 PM
What aspect(s) of this do you consider to be part of what I am trying to get you (all) to see?  Can you elaborate?
I think you are trying to get us to see that we can manipulate the inductance to our advantage.  In this circuit the transformer I used has an inductance of the primary winding of 976 mh with all windings being open.  When I short the secondary winding the inductance drops to 84 mh.  So we charge the primary winding while the inductance is low and recover the energy while the inductance is high.   This causes the cap to charge to a much higher voltage than without the shorting circuit.  I have not had time to try this idea on a pulse motor but I can see how it might lead to a much more efficient motor.  Maybe even to a motor that could generate more power than needed to run the motor.
Regards,
Carroll
i_ron
Quote from: Erfinder on September 26, 2016, 03:19:53 PM
snip
Feels good seeing some trying to see what I see.
Well finally some information! Now I now what you are talking about.
Thanks erfinder ... thanks Carroll
Ron
(Incidentally the two links were the same, JB's never came through)
EMJunkie
Quote from: i_ron on September 26, 2016, 03:48:18 PM
Ron
Hahahaha I wonder why...
Mr Agnostic, Un-Informative, through the imaginary eyes of his Own God, JB!!!
Oh it is sickening, and again, nothing new. People have been doing this for decades! We just discussed the Parametric Oscillator, 1934, image below:
But as long as we can see what he can see... then we will all be saved, because JB will be our God too!!!
Erfinder, You love yourself! As much as you love your own God, JB, and your saviour JM. Keep talking it up, sooner or later youll trip on those Big O'l Lipps...
   Chris Sykes
       hyiq.org
