Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
EMJunkie
Quote from: web000x on September 26, 2016, 05:31:16 PM
Please stop adding this crap to the thread.  If you have technical contributions, cool, but please stop this shit.  Reading countless pages of you all arguing over nothing really is obnoxious.  It doesn't matter who did it first.  We all need to be doing it NOW.
Dave
Dave Agreed - Just saying it how it is, but I agree, its needless drivel that helps no one.
The battery-operated electric drive system for a vehicle uses a resonance pulsation motor supplied with current from the battery via a parametric generator. The braking energy is used for battery recharging and a flywheel is used for intermediate energy storage and to store kinetic energy e.g. so that in the case of a heavy vehicle it can be used to supplement the battery voltage when travelling up on incline. Pref. the generator controlled parametric resonance is obtained by semiconductor control. The system is designed to give reduced running costs since the thermodynamic losses are less, while the delivered mechanical output remains the same.
   Chris Sykes
       hyiq.org
                                  You are acting too fast,Mister C(hris) S(ykes) !
How many publications did the (Prof.) Dr. Florian Goetsch-Popescu applicated ?
Only 1 ?
One(1):
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19840612&CC=US&NR=4454463A&KC=A
Two(2)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=8&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820407&CC=EP&NR=0049214A1&KC=A1
Three(3)
https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=2317724A1&KC=A1&FT=D&ND=3&date=19741017&DB=EPODOC&locale=en_EP
Four(4)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820121&CC=DE&NR=3021154A1&KC=A1
Five(5)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=20&ND=3&adjacent=true&locale=en_EP&FT=D&date=19730315&CC=DE&NR=2143461A1&KC=A1
In der Hauptsache wird praktisch im vorliegenden Falle die Resonanz als parametrische Resonanz durch gesteuerte Variation der Prequenz der Radialschwin- gungen der beweglichen Scheibenteile allmählich eingeführt und systematiseh, nach Notwendigkeit gesteigert bzw. stationär unterhalten. Als anschauliches einfachee Beispiel hierfür gilt das Schiffs schaukeln auf dem Jahrmarkt. Hiervon ging im übrigen der verstorbene russische Gelehrte Papalexi aus, als er das Problem der parametrischen Resonanz eingehend behandelte. Auch der vor kürzerer Zeit verstorbene Pro- fessor Landau aus Russland hat zusammen mit Lifschitz in einem ins Deutsche übersetzte, in der BRD. erhältliche Mechanikbuch ein Kapitel über parametrische Resonanz geschrieben.Desgleichen hat der Urheber dieser vorliegenden Erfindung eine ausführlichere Mitteilung über die Ausnutzung der parametrischen Resonanz bei einem Inertialdrehmotor, der rumänischen Akademie im Dezember 1952 eingereicht. Nach eingehender Prüfung seitens der dortigen Akademie, ist die Angeiegenheit nur deswegen nicht weiter gediehen, weil keine Initiative ergriffen wurde, - wie diese Akademie damals empfahl - den Motor zuerst praktisch zu experimentieren. .......
Sincerely
              OCWL
http://www.overunity.de/2013/radikal-zukunft-design/msg45623/#new #106 date ?
http://www.overunity.de/1631/magnetmotorexperiment/#.V-m_4UVX9aY #4
http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/10635/#.V-nAlkVX9aY user m786 #10648
http://www.overunityresearch.com/index.php?topic=2265.0
et cetera et ....
Mandelstam-Papalexi has been on a very low power level, (Prof.) Dr.Florian Popescu wrote about higher power levels ! Step-by-step-Evolution
It is important to work out the resonanz circuit (motor/generator/transformer) carefully because if not there will become reached the point of no return ergo :
                                           RESONANZKATASTROPHE,
known as movie www.youtube.com/watch?v=j-zczJXSxnw
hoptoad
Quote from: Erfinder on September 26, 2016, 03:19:53 PM
Yes, this is part of the message.  We can manipulate inductive reactive cross section of the circuit, and do so in a  manner which does not necessitate the inserting and removing of a core material.
snip....
Feels good seeing some trying to see what I see.
The fog is lifting, the toad sees where he's once been, knows now where he is, and looks to the future.
Cheers and KneeDeep ...
Hello Chris Sykes,
when you work and listen -with concentration- you would have seen and corrected me for the fault/faught/Fehler/error whose I did :
Professor Mandelstam and Professor Papalexi have been two different humans and persons with whom of each different personalities and characteres and profiles,so I have to correct my mission:
"Mandelstam and Papalexi have been on a very low power level,(Prof.) Dr.Florian Popescu wrote about higher power levels ! "
Trial and Error for Success: to give by translation "1:1=1"  PERFECT SYNTAX by Symmetry
You/we are working on a/the "Dreammachine" ,without concentration it becomes an "Alptraum" Apocalypse "Apos-call-ypse"
        GOoD and BAD
                                                           Believing: in the same ?
                                Who/What consults you and who/what consults me ?
                                          Same level and viewpoint and Realtime ?
What shall the "maschine" have for functions ? Multifunctional ? Transponder-function : the EU-European EUREKA-Program linguage translator ? Materializer ? Dematerializer ? "Scotty,beam me up and contro-versely "Scotty, beam me on" movie "Raumschiff Enterprise" in the german TV ,in the United States of America ? It is an U.S.A. artists production !
This in your hands : Baschir als Assad ,friend or enemy ?
                                Donald Trump ,f. or e. ? Hillary Clinton,f.or e. ?
                                Atomar reacting weapons,friendly or fools their tools ?
                                Thermo-baric re-/actor,friendly or fools their tools ?
Have you childs ? How would/could they(plural)/he,she(singular,sexus) treat the world with such a maschine in their property,possession ?
Wladimir Putin,friend or fool,Dr.Angela Merkel,the Kim in North-Corea and.... ,and ... !
When you are afraid or angry about anybody or anything : making a change by a time-maschine ?
            Ever more or never more seeing,hearing,expeience bad things ?! But are probably this bad things for personal you and good thing probably for the other, or vice-versa good things or situation/-s for specially you and only bad for the other ?
Where is the right Symmetrie by the "balance of Power" "balance of Poorness/Richdom" ?
Gives we as humanity,for example the U.N.-forum/conference for this questions the right true and transparent answer or are you the answer giving right person or I,we two,this forum ?       I think you are male and I am male,have we the right answer also for our human female part ?! Is it better to become borned by the mother as male or female human ? What is about the new defined sexus: Transgender,
the neutral human,officially accepted in India by the estate,but by their society,male part or female part ?
Am I ,you social and experienced enough about moral and/or ethical questions/answers to decide or is this not better discussed by
"academies of sciences","academies of Theo-/Teleologie" or estatal ethical commissions !?
I am confessional working,not professional,but we have enough specialists whose are working 365 days(less weekends and vacations)
to resolve unconvenient problems/questions !
The POPE,has he to work 365 days( mor exactly: 365,25 days per year cause the 23.58 hours and ? sec day,Schalttag,29.February) or is there a Vice-Pope ?When the POPE,the bishop from Rome is in journey,who is representing him ,in Roma ?  Is he not human.too ?
A female POPE,impossible ? Abt(the Abbade-Father hirarchy-rank: bishop . Are there not female Abbas ?
In the rom.-Katholic Churche, I am not writing about the normal situation in the Weltkirchenbund-Organisation(headquarter Genf/Geneve).
Wladimir Putin,a Ras-Putin ? Has he not to show,inner-/outer-estate, to his citizen a kind of "Macho"-personality ? Many enemies/concurrence   !
The Kim-"dynasty" in North-Corea, an hard job ! History and future !?
                                                               Consense !? Common sense ?!
Ranking : Has I,you,he/she/it we/they/ ever to be in the NR.1 competition or is sometimes NR.70000000000 not wiser (to be the Last)
        incende a luz- ascende a luz
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931118&CC=DE&NR=4215818A1&KC=A1
                                                   New matter creation or matter destroying ?
        Does it matter ?
I am a human and I am glad not to be in the political "heads" Imperior/Kings/Presidents  et .et their position become hunted 365 days by the papparazzis for a good (photo-)shot,an exclusive story or exclusive "secret" delivered ! "Poor boys and girls" !
The Prince of Wales-Position is more my alike ,Infante(infnatil,nasty ::) ) /Crownprincipe ! Camilla ? As "ti"(cha/tea) ? Eventually.
WAR IS PEACE /PEACE IS WAR : a provocative these by an Artist ,  "1984" and/or  "Brave new world ?" and finally "ZARDOS" :
we as humans could become- by the bio-technolgy- imortal !?
                              Fantastic or horrible !? For the human society - urban/rural society - flora et fauna - Planet earth ?!
                                                            I like to die,not yet but in the next future.Giving place for the temporal next.
        pearls before the swine throw[/size]
                                               some/many members here in the forum are throwing pearls/visions[/size]
                                                       and there are "swine" and "Glueck/Lucky swine" present[/size]
                                              but too much luck becomes boring or normal and let us forget to Thank                                [/size]
