Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
"alter-auto" : alter,Latin:means high/deep= amplitude           amplitude modulation  AM
        frequency      "              FM
linear mono-phase alternator                                                   Amplifier,Frequency Equalizer:Resonator
linear poly-phase alternator (2,3,4,...)
https://patentscope.wipo.int/search/en/detail.jsf?docId=WO2016070292
Sincerely
              OCWL
p.s.: Ether,Aether = RF-spectrum ,german: Funkenaether/Funkenstrecke Funke=Signal/Pulse             "Radio Tele-Funken"
        Radio-Station to TV-Station
        https://www.youtube.com/watch?v=W8r-tXRLazs
i_ron
Quote from: webby1 on October 02, 2016, 10:10:51 AM
I have tried reversing D10 and D11 which then would place the connection from the input V2 across the load out of U2 and U3,, that may not make any sense to try it,, but I try these things anyway because you do not know until you try it.
I am using a cored transformer and this may be problematic on its own,, maybe not, but that then tells me I need to try all of this stuff without the core.
That is just how I go about things,, I don't care so much as to how much my meters show,, but rather what is the change in what they show for what changes I make.
If I am using only one side of the transformer, D11 is open,, then what would you expect? if I have a 50 ohm dropping resistor between V2 and D2 what should it show?  If I have a meter between the V2 side of D2 and D10 what should it show?
The load on U2 is a 10,000uf cap and a 1462 ohm resistor just in case you wanted to know,,
Right now I have replaced the dropping resistor with another transformer  (10:1) in step up just because I can,, and I am wondering then if the current the dropping resistor is showing that should be there is there,, I should be able to take an output from the secondary of that transformer,, and then what should my meters show?? my meters say there is 1.45V AC across the transformer and the secondary shows 26.5V DC rectified and using a 1642 ohm resistor,, I fed it into the same resistor and cap that U2 is connected to.
Now I ask why is the dropping resistor showing 4.25 but the transformer is showing 1.45,, and that is where I am right now,,
These are running at 60Hz US power grid :)
Thanks, You are calling the wall wart T1?
T2 and T3 are on the same core? This is off the shelf? hand made? Coils are (ball park) size, ohms?
The 50 ohm resister floats and is not shown?
Ron
Quote from: webby1 on October 02, 2016, 10:15:12 AM
Mexican Radio,,
https://www.youtube.com/watch?v=eyCEexG9xjw
I remember seeing these for there first broadcast,, times have changed.
A kind of "Punk wave"(german "normals" decision: Punk is krank/ill ! 8) )
Syntheziser and Sintonizer of our feeling/-s by listen the amusement(passive) ,and by artists to get listen (active) the muse ,by over-and under-tone tuning (a.The Mission  b. The Mission formerly ...) !
                       Life - actio/reactio : feedback cycle
"I am not amused ! An(n)us horribilis ! "? Sitzt wohl zulange auf dem Thron ?!
                                                Radio-gugu-radio-gaga
                   https://www.youtube.com/watch?v=fRPtRmwyKFs
        Punk is also a kind of : okay,extremly !, applied religion ,the trial/the temptation of "wake up !"
             with and without B.E.F. ,Heaven17
  :o   https://www.youtube.com/watch?v=xNnAvTTaJjM
               Not burning down,refurbishing and reengineering the "Haus Erde" .
        "Lenz free" generator = resistance free generator                       Term/-inus : Attractor
        attracting
        anziehen
https://www.google.pt/search?client=opera&q=attractor&sourceid=opera&ie=UTF-8&oe=UTF-8
to
http://www.chaos-math.org/en/chaos-vii-strange-attractors
             virtual to real
        Praemisse:
        physics       !?   Pole ziehen sich an,
        physics       !?   Pole weisen sich ab
        real life             but: Paradox inside
web000x
Quote from: webby1 on October 02, 2016, 09:09:52 AM
I am running through several setups,, but these kind of cover the basic starting place.
Each one is just a set of connections that I am pondering,, I have many that I wish to try ,, I am mainly looking for trends and tendencies,, and then when I find something like this mysterious condition that, while there is a large load against it, there is an increase in the voltage from the wall wart.
Have you tried magnetic energy recovery with this yet?  It seems like you are using it with a steady state AC supply.  What if you pulsed one coil and the rectified the inductive collapse across all of the coils into a cap?  This is what I thought Erfinder was hinting at.  I could be wrong..
Dave
i_ron
Quote from: Erfinder on September 30, 2016, 12:52:56 PM
I'm not playing a guessing game.  Folk must think for themselves, I am not here to provide blueprints of things I have done, am doing...Nor am I intersted in reviewing blueprints provided by others.  I am not asking anyone for anything, and don't recommend that folks ask each other for anything.  The answers we seek as individuals are found in properly formulated questions, questions which are projected within to the innermost reaches of the individual, it's here where we answer our own questions.  I am here to exchange with people who rely on themselves, individuals who are travelling that road which leads within, folk who can and do stand strong in a deluge of spit, name calling, sticks, and stones.
What have I found.....to put it plain....answers to my questions period.
What an alien concept. Although the wheel has been invented we are not to tell anyone. Each person must see the need, follow through and invent the wheel individually. No one is allowed to help another in this quest, it is forbidden. What a ghastly world that would be. (is)
"Regards", esteem, affection, or respect
Ron
