Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
EMJunkie
Quote from: tinman on October 08, 2016, 01:14:24 AM
Chris
Would you like me to show you how to get the armature out of the steel housing within seconds,without a scratch,or without having to even pop the retainer pressings out.
20 seconds-thats all it takes Chris.
As i said,there are ex-spurts,and then there are those that know what there doing,or how to do things.
Brad
Hi Brad, its your call what you do, or want to do.
Perhaps you would like to join the Build Off Party and see if we can all make some progress?
Its entirely up to you what you do, but I would like to replicate this with some accuracy and I am sure at least one other person here would also.
Asking questions is only logical when questions arrise, isnt it?
   Chris Sykes
       hyiq.org
tinman
Quote from: EMJunkie on October 08, 2016, 01:22:56 AM
   Chris Sykes
       hyiq.org
Well Chris,it's like this.
It seems to me that you are doing your best to point out negatives that just do not exist in your build attempt.
The first one being that to drill the hole through the laminated core would be next to impossible,as per the engineering shops comments.
Second,you say that it is near impossible to get the stator out of the housing without damage of some sort,and you point out that there is no damage what so ever present in or on the housing of my motor.
First i showed you that a hole can be drilled into a laminated core with ease--if you know what your doing. This puts your first !near impossibility! into the !easy as! basket,and shows that it can be done with ease-with any size laminated core.
So now i will have to put the second concern to rest,in that you find it hard to believe that the stator can be removed within 20 second's,without so much as a scratch.
So i'll be back in a while,to post the video,that once again will show you that what you think near impossible,is done with ease.
QuotePerhaps you would like to join the Build Off Party and see if we can all make some progress?
No,i would not like to join the build off. That is reserved for those that junk my work,but as seen many times now,will never take me on.
QuoteIts entirely up to you what you do, but I would like to replicate this with some accuracy and I am sure at least one other person here would also.
I have shown you that it is quite easy to drill the hole in the laminated core.
I will soon show you how easy it is to get the stator out.
As i clearly stated way back in the thread where the measurements took place,under the guidance of PW and MarkE,there would be no full disclosure of the entire workings of the RT--and that remains to date.
Brad
tinman
Quote from: forest on October 08, 2016, 02:16:09 AM
Do you know maybe how to to remove generator from the case of portable generator without special tool ? https://www.google.pl/search?biw=1280&bih=877&tbm=isch&sa=1&q=generator+650W&oq=generator+650W&gs_l=img.3...6800.8050.0.8203.5.5.0.0.0.0.147.655.0j5.5.0....0...1c.1.64.img..0.4.525...0j0i19k1j0i30i19k1j0i5i30i19k1j0i8i30i19k1.RjrY5VuhL7E#imgrc=FTMnia6XjGMRTM%3A
There is a flywheel inside  :(
Just in case you know everything  ::)
First-yes,i can completely strip one of those in under 15 minute's-thats my job,and i have many of them here.
Second. There is no flywheel inside,only the rotor and armature. The flywheel is on the opposite side of the motor to that of the generator.
Brad
tinman
