Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
0 Members and 63 Guests are viewing this topic.
i_ron
Quote from: Erfinder on October 30, 2016, 01:01:51 PM
Without exception, as far as I know....every motor generates.  Alexander, among others recognized this.   Once this is accepted, a great deal of time and energy is invested in trying to find a method through which the output of the generator operating inside the motor while motoring, can be redirected from the supply to an external load.
I notice on re-reading your old posts that my description of a motor/generator matches your description very closely. What was the difference you were trying to make?
QuoteI am also dusting my insanely large 12 coil pulse motor and making a few modifications on it so that it to will produce this effect, using 2x of its trifilars as motor coils, and the rest as gen coils which will supply a huge transformer based reactor which amplifies the effect.
Ron
i_ron
Quote from: Erfinder on October 31, 2016, 02:38:28 PM
Your description is nowhere near what I am suggesting!  You separate the two, just like you are taught to....I do not.....let that sink in.  A motor is a generator!  Comprehend that sir, then approach me, otherwise, you are wasting both of our time.
A catch-22 is a  paradoxial situation from which an individual cannot escape because of contradictory rules. An example would be:
  "How am I supposed to gain experience [to be hired for a job] if I'm constantly turned down for not having any?
Ron
shylo
whether they are motoring or generating all coils are pumps.
when they pump ,they create opposite waves (magnetic fields).
the opposite fields create waves, which are opposite again the same as the first but at a different time.
when is the best time to induce a coil that is generating , I do it when the coil has produced its' max output
just when Lenz is about to cause drag.
Re-route the generated output to induce motoring.
artv
tinman
Wow
Never seen so much rocket science being used that dosnt result in liftoff.
Brad
tinman
Quote from: webby1 on October 31, 2016, 03:09:06 PM
Motor Generator,,  Really?
They are a transfer pump\conversion pump.
My interpretation has always been that Erfinder makes pumps.
QuoteOne is called a Motor when it is taking a higher potential and reducing it by some means
No
QuoteOne is called a Generator when it is taking a lower potential and increasing it by some means
No
Both are transformers,that transform one form of energy into other forms of energy.
An electric motor takes electrical energy, and transforms it into both heat and mechanical energy.
An electric generator takes mechanical energy,and transforms it into electrical and heat energy.
The potentials of this transformation are always equal,as you cannot create or destroy energy.
Brad
