Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
tinman
Quote from: Erfinder on August 08, 2016, 09:04:31 AM
That's funny....
QuoteBrad would have everyone's attention, maybe even mine if he finished what he started, he won't.....so hes no better than he says I am.
What you mean to say is-i am un aware if Brad has finished what he started.
Just because you cannot see something,dosnt mean it's not there.
OU is not the only forum i am on,and there is another very few people know of,and not all is found on youtube  ;D
Brad
tinman
Quote from: hoptoad on August 08, 2016, 08:42:26 AM
I'm aware of your RT work Brad. However, in this instance, I am more curious about Erfinders AIR core configuration.
Cheers
No problem hoptaod,i hope Erfinder can help you out.
Brad
i_ron
For those interested in the Zero force Motor
Ron
https://youtu.be/yC4g0XCgEqM
EMJunkie
Quote from: tinman on August 08, 2016, 05:53:15 AM
And mine decreases the required P/in,but increase the torque with a gain in RPM.
As i stated before,the lorentz force must be increased-not decreased as many believe.
In order to do this,you must maintain current flow value throughout the RPM range,without having to increase the voltage.
This is what i have achieved with the L.A.G. Current value is maintained by increasing (what most refer to here as) Lenz,not decreasing !!Lenz!!.
Lenz is a law,and so using lorentz force is more applicable here.
It is a miss-belief that in order to gain acceleration under load,you must decrease !Lenz!,when in fact,to maintain current flow,while your electric motor still acts as a generator also,is to increase the lorentz force--and there is only one way to do that,and it is opposite to what others are trying to do.
Below are two video's where my research into this !speed up under load! started.
The first one shows not only a gain in torque,but a decrease in power consumption also.
The second video shows the RT up against an !off the shelf! motor,in way of a house fan.
https://www.youtube.com/watch?v=x6xRcSkPYn4
https://www.youtube.com/watch?v=szpJ97M58G4
Some of us talk,and some of us do.
Brad
@Brad - The "Lorentz Force" may not be clear to many, as it is the total Force (F) exerted on a Charge (e) when moving with Velocity (v) in a Magnetic Field (B) - See Below Image.
See:  Lorentz  force
I agree with what you're saying, and yes it is a case of Increasing and not decreasing the Forces we are working with. In the immediate localised area.
Decreasing is specifically meant in a context, from Output to Input, not in the total System. Which is what the RT shows as we all know!
@All:
Anytime Electromagnetic Induction Occurs, there is a High Stress Area between the Source (Primary) and the Destination (Secondary), the same is true between any array of Coils that Electromagnetic Induction occurs between. It is true that any Magnetic Field Changing in Time can invoke Electromagnetic Induction!!! Weather this Magnetic Field be the 1st or the 7th...
Count all the Fields in your device, understand each one and where it is coming from! Understand that each Magnetic Field changing in Time can be the Source for Electromagnetic Induction again, and the chain goes on...
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: Erfinder on August 08, 2016, 10:40:25 AM
What I mean is exactly what I said!
Regarding your RT, I'm not looking.....because I am not interested.  I am just voicing what I pick out of the ether chatter......
