Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
web000x
Quote from: Erfinder on November 24, 2016, 02:52:09 AM
Irrespective of how many ways there are, or how many methods there are, the one which matters most is never considered.
The speed of motors without sophisticated control are generally governed by the input voltage.  It is from this standpoint that I make my suggestion, specifically, we can learn to use the EMF that the motor itself is generating to augment the applied EMF.  The two already have a more or less 180° relation, here the applied dominates the induced, and we are left with a differential.  Try and see the machine from the perspective of the force operating within it.  Allow it to dictate the necessary steps for inverting the induced so that it aids the applied.  I have shown in a rather vague presentation that this is not theory, it is a reality.
I've been slowly solidifying my test bed and working out some kinks in design.  I'm not there fully as my method of biasing my reactors doesn't give me the true swing in inductance that I need.  I'm having problems with the mosfet's flyback diode being a path for current in that direction. I need a low impedance mechanical style switch or maybe add a schottkey diode against FET's diode if I want to go that route of biasing my reactors.  On  top of that, I somehow seem to have fried my arduino processor that was optically isolated from my power circuit...  One thing after another, I am still moving forward with this and believe that I might be getting an understanding of what you are doing, though I have not done it yet.  If there is something here, I will find it.
Is this the magnetic version of the dielectric concept that armagdn03 presented in the Charge Conserving Capacitive Spring Thread?  [size=78%]http://www.energeticforum.com/renewable-energy/6557-charge-conserving-capacitive-spring.html[/size]?
Dave
The difference between a battery and a capacitor in a resonant circuit is the time reaction,
the last development has been the industrial prototyping from 2dimensional to 3dimensional capacitive material with up to 60 times improvement ( like the relationship from 1 cbcm active-coal in volume to this in sqcm aktive surface area!) !
In the solar-cell development there is one time handicap to get high efficiency : the recombination,
similar is happening in the resonant circuit !
Quantum Physics: Plancksche Quanten-Paar, Paar=Teilchen/Welle,Photon/Phonon
                                                             magnetic diode
The worldwide R&D scene is not sleeping ,here some examples
https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwww.buch-der-synergie.de%2Fc_neu_html%2Fc_10_03_batterien_q.htm&edit-text=
Quote from: webby1 on November 24, 2016, 12:12:25 PM
This is the style of motor I used last night to double check things.
I connected the coils for one phase in series to increase the voltage,, but other than that when you hook the cap and source up and spin the rotor there is almost no force needed to spin,,
Okay,which is the nominal RPM-number and the generated torque ? Without and with modification ?
        The no-/partial/full load consume with and without modification ?
What do you think about the cap/motor relationship related the inrush current and inrush tension ?
                                  Temperature measurements without and with modification !
i_ron
Quote from: Erfinder on November 24, 2016, 11:05:29 AM
F U C K O F F
ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
i_ron
Quote from: Erfinder on November 24, 2016, 10:49:54 AM
.my days here are numbered.....I hope.
Steve, I believe that the background field is resonant at 333000 Hz and this is what powers all matter and energy forms on earth.
In patent number 588,179 we see the two short antennas to bring in the back ground field. Can you better describe what you are seeing in your work that is so different?
Thanks, Ron
