Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
Quote from: i_ron on November 24, 2016, 01:28:55 PM
Steve, I believe that the background field is resonant at 333000 Hz and this is what powers all matter and energy forms on earth.
In patent number 588,179 we see the two short antennas to bring in the back ground field. Can you better describe what you are seeing in your work that is so different?
Thanks, Ron
                                                     Is this pro/contra your believing ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931118&CC=DE&NR=4215818A1&KC=A1#
  Matter is chemically -elementary- different,Eigen-Frequency,why only one -333000 Hz- fixed frequency "powered" ?
                                What is your meaning here: "powered" related ?
                                                     especially "( all matter and )energy is powered"
                                                          Erfinder,
                                 Date Registered:                 May 11, 2006, 11:18:14 AM
                                                more than ten years !
i_ron
Quote from: Erfinder on November 24, 2016, 01:44:56 PM
F U C K O F F
That is an ambiguous answer, what exactly do you mean? do you mean you don't know, or what?
Ron
https://vimeo.com/190251670            http://rexresearch.com/tewari/tewari.htm
Electromagnetic Induction of Space Substratum
by
P. Tewari
(Reprinted from Journal of Borderland Research, Jan-Feb. 1992, p. 16)
Introduction:
A cylindrical electromagnet, rotated on its axis, develops dc voltage between the axis and the periphery though there is no relative motion between the magnetic field in the core parallel to the axis and the iron conductor of the core. Refer to Figure 1. Faraday (Ref. 1) had discovered this effect by rotating together a permanent magnet and a copper disc integral with it. Bruce DePalma (Ref. 2) while carrying out the experiments on rotation of magnets independently discovered this phenomenon and named it "N-Effect". Development of the N-generator by DePalma, homopolar generator by Adam Trombley (Ref. 3) and Space Power Generator (SPG) by the writer operating at "overunity" efficiencies and in violation of the "Law of Conservation of Energy" in its existing form is based on this new system of rotating assembly of magnet and disc conductor, in which the magnetic field and the conductor have zero relative motion. It gets evident that there are more basic aspects to Faraday's law of electromagnetic induction than what has so far been recognized.
Figure 1:
Figure 2:
In , a conductor C is placed transverse to a magnetic field B from a magnet M. electromotive force (emf) is generated in C if it is moved as shown in the figure. Also if C is kept at rest and M is moved, emf is generated in C. In another case, if current is changed in a nearby conductor C', the changing magnetic flux of C' will induce an emf in C. In the above cases, there is either relative motion between C and B, and B thus cuts the conductor or there is a change in the magnetic field B' of the nearby circuit conductor C' and the changing field B' interacts with C to produce emf. In SPG also the magnetic field is in contact with the rotating iron core conductor and emf is produced without relative motion between the conductor and the magnetic field. The common feature in all the above cases is that for the generation of emf in a conductor, interaction with the conductor of either steady magnetic field or changing magnetic field is essential.
An experiment with rotating electromagnet described below has, however, shown that emf can be induced within a rotating conductor even when it has no direct interaction with steady or changing magnetic field. With this experiment, a conclusive proof is had that the absolute vacuum (space) is the fundamental substratum of reality that can undergo magnetic induction and transmit the emf induced in it to the conductor rotating relative to it.
Experiment:
Refer to Figure 1. The magnetic circuit of a rotating electromagnet completes its path through static iron limbs on either side and the base. In the four slots cut in the cylindrical iron core, provision is made for non-magnetic stainless steel (ss) rods that are welded with the non-magnetic ss ring surrounding the core. The magnetic field produce by the dc current in the coil, which is integral with the core and rotates with it, does not pass through either the four slots or the rods mounted within the slots. When the assembly is rotated, the magnetic field remains confined to the core, air gaps on either side of the core, and the base. Measurements show however that the ss ring develops the same dc voltage as the cylindrical core's surface on its periphery (although the ss ring and the rods are neither in contact with the periphery of the core nor have magnetic fields in them). Even when four thin slots are cut in the ss ring making the rods independent, the same voltage is induced in the ring. It is inferred that the zone in which voltage is induced in the rods is within the slots and since the magnetic field in the core surrounding the slots is a steady field due to dc current in the electromagnet's coil, electromagnetic induction as conventionally understood cannot induce emf in the rods. The space surrounding the rods in the slots has to be a real medium that has to somehow generate emf in itself so as to transmit the same to the rods.
"Static" & "Dynamic" Space Substratum:
The effect of generation of emf in the above experiment can be explained by introducing "static" and "dynamic" aspects of space substratum as discussed elsewhere in the writer's works (Ref. 4). The interatomic space within the iron core along with the "space vortices" that constitute the atoms of the iron core, the ss ring and the rods form one system of dynamic space that rotates relative to the static space. Within the iron core, however, the rotating space is super-imposed on the stationary space, and, therefore, the magnetic field there is common to both the rotating as well as the stationary spaces. As the space of the rotating iron due to rotation shifts along with its magnetic field, it leaves behind within the slots static space with magnetic field falling to zero there. This causes induction effect in the static space of the slots. The ss rods moving through the stationary space within the slots pick up the emf induced there and are thus raised to the same potential as the periphery of the core. If the space medium within the slots around the ss rods is considered an "emptiness", in the absence of any magnetic field there, no electromagnetic induction is possible and hence the ss ring cannot develop emf with steady magnetic field in the core contrary to experimental evidence.
Conclusion:
The following conclusions are drawn from the above experiment:
A rotating electromagnet carried with it during rotation the magnetic field in interatomic space of the core produced due to the coil integrally mounted on the core of the electromagnet (as the source of the magnetic field [coil] rotates, the field also rotates with the source).
The steady magnetic field in the iron core in its transverse motion of rotation produces emf in the neighboring space (within the slots) due to electromagnetic induction of space caused when the magnetic field in the core shifts relative to the stationary space substratum in the slots.
The radial flow of load current in the electromagnet's iron core and the magnetic field in the core transverse to this current, interact within the rotating pace system of the core which is independent of the external stationary space system. The resultant force between the current and the magnetic field is thus contained within the rotating space system and does not produce torque opposite to that of the prime mover that rotates the electromagnet.
References:
1)  Martin, Thomas (ed.): Faraday's Diary; 1932, Bell.
2)  DePalma, Bruce: "On the Possibility of Extraction of Electrical energy Directly from Space"
3)  Trombley, Adam D., Director of Research & Development, Zero Point Technologies,Inc., P.O. Box 1031, Evergreen, CO 80439
4)  Tewari, Paramahansa: Beyond Matter; 1984, Print Well Publications, Alighar, India.
5)  Tewari, P.: "Generation of Electrical Power from Absolute Vacuum by High Speed Rotation of Conducting Magnetic Cylinder"; Magnets in Your Future 1(8), August 1986.
6)  Tewari, P.: "Violation of Conservation of Charge in Space Power Generation Phenomenon"; The Journal of Borderland Research, vol.55 (5), Sept.-Oct. 1989.
7)  Tewari, P.: "Detection of Stationary & Dynamic Space Substratum"; Raum & Zeit, USA, 2 (1), 1990.
i_ron
Quote from: lancaIV on November 24, 2016, 01:41:22 PM
No, I was referring to a previous post on this subject.
Ron
http://www.resonantfractals.org/index.html
