Where is the 1 watt TPU topic?
Started by gotoluc, December 22, 2014, 09:01:31 PM
gotoluc
Hi Stefan and all,
I see there is a new video which Overunity.com is presenting but I see no topic of discussion for it?
Here is the video in case you don't know what I'm talking about
https://www.youtube.com/watch?v=2cqk7fijGG8
What is going on and will this be shared for replication?
Thanks
Luc
d3x0r
certainly deserves it's own thread... need some good reverse engineers :)  Never see the bottom of the board; lots of guesswork...
MarkE
That demonstration is extremely weak.  The led loads are perhaps a few mW.  That is easily within the range of just the visible capacitors driving the LEDs through a voltage regulator.  Connectivity through the toroid can be used by the circuit as an on-off.
Oh come on, where is your imagination?  The electrolytic capacitor can could be gutted and stuffed with 3 or 4 3-volt button cells in parallel. These, combined with a simple Joule Thief boost oscillator circuit, could keep the LEDs lit for many hours. And looking at the bottom of the board would not reveal anything. The coil can complete the connection, and even act as the inductor in the JT circuit. Or a tiny inductor looking like a resistor could be used. A simple logic circuit can make the latching power-on function, so that the system would not start lighting the LEDs until some external connection to a "startup" supply is made; then the startup supply could be disconnected and the system will stay on. The LEDs aren't as bright in Stuttgart as they were back home because even with highly efficient JT boost circuits the batteries do eventually run down. The components we see on the board are entirely consistent with my hypothesis. The disassembly of the coil is a great Red Herring; note how he "casually" pushes the board aside so you don't have to worry about it any more. No tests are performed that could rule out the batteries-in-the-can trick, which I believe Akula has used before several times. Take a pair of diagonal cutting pliers and move towards the board with them, threatening to cut the capacitors apart, and watch Akula freak absolutely out.
It is trivially easy to take an electrolytic capacitor apart without damaging the case and replace the guts with batteries. It is trivially easy to make a circuit, battery powered, that starts up by making a connection, either with an external startup supply or just a shorting jumper or switch. It is trivially easy to make a Joule Thief circuit that will run a dozen LEDs for a long time on some tiny button cells. And, obviously, it is trivially easy to fool gullible observers who do not know how to examine claims like these critically.
MarkE
TK I don't know if you were addressing me or not.  I agree with you completely.  The demonstration could have been done any of the ways that you listed.  For the relatively short run times shown even an unaltered capacitor would work.  One filled with SR-10/E76 cells as you suggest would be able to run for a very long time.
