T-(Shaped) Turbine, Which uses Centrifugal Force
Started by Overunityguide, December 24, 2014, 05:49:39 AM
DaS Energy
I like your work. It may help the finished design if you drop the Pelton runner and the generator from the end of swing arm and instead have one centre mounted up above the swing line. The centrifugal drive forces remain and much of the inertia weight is removed.
The drive resembles a pyramid shape with a hole in the top apex, so allowing water flow produced by the swing arms action.
mihai.isteniuc
Hi 2 all,
Pls find attached a document with the conclusions of a team regarding a pico Pelton turbine. The document covers some aspects regarding construction an conclusions after the successful build of the turbine from a more practical point of view.
Mihai
Overunityguide
@ Mihai, Nice Document on the Design Process of a Pelton Wheel. THX
@ miloszlaw, I think I don't understand what you are trying to accomplish by replacing the rotating tubes with your rotating cylindrical structure. (as can be seen in your Drawing) This because with a rotating cylindrical structure only, there cannot be exerted as much Centrifugal Force on the water compared to when we use a rotating T-(Shaped) Pipe Structure. And furthermore the guide way structure next to each individual Pelton Turbine is also unnecessary in my opinion. This because they are Impulse Turbines. (Please look for the inner workings of Pelton Impulse Turbines on the internet)
For the Self Propelled version, see the Rotation direction indicated by the Arrows. (Counter Clockwise in this Case) This version only works with pulleys and driving belts. So No generators attached...
Overunityguide
After a two week testing period during the Christmas holidays, I have tested multiple test rotors for the T/S-(Shaped) Turbine Concept. After this I have now created a wrap-up video, in which my conclusions are being discussed. I also give some extra information about the self-rotating T/S-(Shaped) Turbine concept, which can be built by making use of two simple Pelton Turbines.
Here you will find the link to my new video about my Final Conclusions:
http://youtu.be/BHsB_-h7kkg
mihai.isteniuc
Hi all. I decided to give it a go to this project. Evolution will be slow 'cause lack of time. I'll keep u posted with the findings along the way.
To OUG: did u receive my pm?
Mihai
