Cold Electricity Breakthrough With Two Tank Transformers! Must Watch!
Started by Just..Sayin.., December 26, 2014, 01:00:34 PM
allcanadian
@Mark E
QuoteAgain, I am not seeing anything that looks special.  What is the claimed
special behavior?
You need to be an expert to see those cold electricities which are made of gravitons and zipons. Why if we got our wires crossed every time we turn on the switch we might fall on our heads due to gravy-zipo transdjuctions... which explains a lot of things. He's done got his wires crossed.
AC
MarkE
Quote from: allcanadian on December 29, 2014, 09:39:20 AM
@Mark EYou need to be an expert to see those cold electricities which are made of gravitons and zipons. Why if we got our wires crossed every time we turn on the switch we might fall on our heads due to gravy-zipo transdjuctions... which explains a lot of things. He's done got his wires crossed.
AC
I forgot all about zipon subduction zones.
pomodoro
Quote from: forest on December 29, 2014, 04:40:06 AM
you didn't understood  8)  like you didn't understood Tesla radiant energy receiver patent
we can disconnect EM from the source of electrons and pull electrons from open path (Earth ground)
this decoupling is already done in radio transmitters
how do you use antenna gain without transmitting ?
You don't even need the earth. You can couple the current to space.  The output of  the transmitter can be a transformer with an open secondary.  The secondary wires go to two lengths of wires each 1/4 wavelength - a dipole. Magically all power to the transformer, even kilowatts,  disappears.
The earth is sometimes used as a mirror for a 1/4 wave vertical antenna. Its called a Marconi antenna.  There is no more pulling of electrons than there is from the 1/4 wavelenth piece of wire it replaces.
Antenna gain is by the ingenious use of tuned lengths of wires, which when receiving a signal interact constructively in some direction.  Tesla did nothing OU, he wanted to send power for free, but the power was made by generators.
Hoppy
AC
If you worship your clamp meter anything is possible. ;D
MarkE
Quote from: Hoppy on December 29, 2014, 11:24:17 AM
I tried sacrificing reels of 30AWG wire to mine.  It didn't help.  Maybe the problem was that the insulation was recycled and not virgin.
