Sotogen
Started by l0stf0x, December 29, 2014, 10:47:13 AM
l0stf0x
Hello, I name the idea Sotogen
The idea is to turn the core it self, with stable coil around it as close as it can. By doing that you remove the second gap of the clasic rotating iron and so we get only one gap as a regular generator has, so the losses are minimal.
The drag of the core at full load will be close to 0.  The core here is invisible for the coil, even its turning.
take a strong magnet and stick it to a small motor , with one pole point out and one in and as it turns, insert it in the copper pipe.. what you see? no drug? ;)
the swithing of poles is easy to understand from the diagram, number of poles and magnets has to do with speed, and less or more clogging. But clogging can easyly bypassed by combinining many sotogens in a circular mode with gearing and different timing so the clogging will be history.
The core material must be laminations or ferrite or any modern high switching frequency core material.
The construction looks easy but needs work :)
i ll be around for any question :)
MarkE
It is a variation on a stepper motor.
madddann
Hello l0stf0x
Could you please make a drawing of the experiment cited below so there is no missunderstanding?
Quote from: l0stf0x on December 29, 2014, 10:47:13 AM
Was this the experiment that led you to the Sotogen drawing - could you please explain in detail what experiment led you to the Sotogen?
THX in advance!
l0stf0x
Quote from: madddann on December 29, 2014, 02:48:06 PM
Hello l0stf0x
THX in advance!
the setup is shown at the diagram.. test it
the magnetic mass/flow does not change for the copper even the core is turning. because magnet's or core's flux is always even at every side and the coil just see a stable core. But using this we can get the switching easy... just do the test
gotoluc
Thanks for sharing your very interesting Sotogen design idea l0stf0x
Luc
