Produce Gold
Started by franco malgarini, January 02, 2015, 04:45:12 AM
franco malgarini
Roberto Monti
And 'my intention to provide sufficient information to demonstrate
clearly:
A) That the "principle" of Lavoisier is scientifically unfounded
(23).
B) That Alchemy is a truly experimental science
by an experiment easily reproducible by anyone
with little expense.
To this end, I chose a variant of the methods below to
Geber (5) for the preparation of the Philosophical Mercury, which is a
particular configuration of the isomeric Mercury "normal" or
"Vulgar" (9), (23).
Take therefore 1 kg of Mercury (Hg). For example: Carlo
Erba Reagents. Code No. 460737. Cost: L.221000 + VAT.
First operation.
Dissolve 100 g of Hg in nitric acid (HNO3), 65% RPE,
for analysis, for example: Carlo Erba. Code No. 408022. Price: to
liters L. 21,800 + VAT (for 6 liters: L.17100 + VAT per liter) in the proportion
1:5 (example: 100 cc of HNO3 + 500 cc of distilled H2O.
Ipercoop L.1650 for 5 liters).
It 'just put the Mercury within a beaker of 250 cc
Pyrex glass (L.6400 + vat).
Mercury is verses on the solution of nitric acid 1: 5 to fill
the beaker.
Poses the beaker on a hot plate (L.100000 + vat)
adjusting the temperature to 90 ° C using a standard thermometer
Mercury (L.18000 + vat).
The dissolution can be done easily within a day (is
add the solution of HNO3 + H2O hand in hand that evaporates
taking it from the 600cc).
The Mercury will dissolve completely, showing that it does not contain
signs of appreciable gold.
Second operation
Arise the remaining 900 g of Mercury in a glass container
(I find excellent packages of jam Zuegg "Traditional"
once eaten jam. Ipercoop L.3970).
It verses above the Mercury a mixture (50%) of wine vinegar
white (Ipercoop. L.1350 per liter) and Acetic Acid Glacial 99 -
100% (Polichimica srl. Bologna. L.8000 per liter + vat) to
level of the second bulge of the jar Zuegg.
Third operation
It seals tightly the jar and shake the contents until you
see the Mercury divided into tiny balls (a few minutes).
Let it be placed in the shelter of a locked drawer.
Repeat this operation preferably daily, when
comes to mind.
Fourth operation
After 10 to 15 days (enough to eat calmly content
of a second package of "Traditional Zuegg" and
so have a second jar) "scum" beginning to
"Exit" from Mercury.
And 'appropriate at this point "clean" the mixture of vinegar and
acetic acid using the second jar Zuegg.
AThis purpose agitate the contents of the first jar until
lees are well suspended in the solution.
Then pour the solution into the empty jar (taking care not to
pay also Mercury) to fill out the first (to the level indicated)
with the solution prepared above (to preserve the
which fits any glass container).
Fifth operation
Let the solution stand of the second jar until the
lees are well deposited on the bottom (10 - 15 days).
Repeat the fourth operation for about four months, when there is
comfortable.
Two jars of "Traditional", a liter of white wine vinegar and a
liter of acetic acid are therefore generally more than sufficient.
Sixth operation
After about four months (depending on the efforts) can
extract the first Gold since Mercury.
So you take 100 g of Hg "Treaty" and dissolve them in acid
Nitric 1: 5, as in the first operation.
Mercury dissolves slowly, and when it is reduced to a
ball, beware.
At one point "explode" expelling all Gold product
will disperse on the bottom of the beaker in the form of a "dust" of
specks of gold very beautiful to behold.
I have done many times Gold in different ways, but the gold extracted
directly from Mercury in this way is the most beautiful I
have ever seen.
You can then repeat this process eight times and produce
enough gold to dispel any doubt about the reality of this
Alchemy (advice to "clean" the Gold product with a solution
1: 2 HNO3 + H2O. After that, washed with distilled water
and dry your gold into the beaker on the hot plate.
Stored in a glass container also nitrate
Mercury product from time to time).
profitis
Really interesting.I have it all the ingredients.looks like common theme is dissolution in hno3 where products NO2,N2O gases release.obviously the release of gas is increase entropy which might exceed prior entropy balance books (qv.water electrolysis) and resultente lenr perhaps? Worth investigateur
Pirate88179
It would be easier to convert lead into gold as they are closer on the period chart.
Hell, the Chinese are doing this already...by selling gold plated lead coins as pure gold coins.  Yes, people are buying them all the time.
