The 'free energy' spark
Started by pomodoro, January 06, 2015, 02:30:01 PM
PolaczekCebulaczek
what about rectification tesla coil output with huge diode or vacuum tube? would this make a DC from tesla secondary?
Vortex1
Quote from: PolaczekCebulaczek on November 09, 2016, 04:42:40 AM
Yes it would, I have done the experiment and you can charge capacitors to quite a high DC level.
It may take a while to build the charge depending on the size of the capacitor as there is (usually) very low current on the secondary.
Be very careful when performing this as you can accumulate lethal amounts of Joules when the energy is stored over time.
A Tesla coil being basically a moderate frequency tuned (resonant) radio frequency step up transformer, or TRF transformer in engineering terms.
If the frequency and voltage gets very high, you might have better results with a vacuum tube rectifier like a 1B3, 1X2 etc.
I agree that Pomodoro has offered a litmus test for the "don't kill the dipole" mantra in post #32.
Nevertheless, I do believe what we now are calling "OU" may someday be possible, however when it is, there will also be discovered the source of the energy, so the term will then be moot, and the energy will no longer be anomalous as the source will then be added to the COP equation.
By the way IMHO Pomodoro has to his credit correctly identified just a few of the members of what I call "The Free Energy Circus"
The "circus" is replete with all the usual clowns, jugglers, monkeys,  and dog and pony shows, spinning wheels and you might even find for your amusement something like a Ferris Wheel. On the sideshow you will find the battery shell game, where you have to guess which battery has the charge. People that speak in strange techno-babble can also be found in the side show, next to the mustached lady and the hermaphrodite.
You buy your ticket and take the ride in this show, which to the uninitiated, is a jaw dropping high (tension) wire act.
In my youth, before I became experienced, back when I was easy prey for the hawkers, I spent a good share of money at the circus buying books and DVD's that promised everything (secrets of this and secrets of that) and delivered nothing, great vaporous claims, which for the circus members is indeed a source of infinite free energy (your energy and my energy).
As P.T. Barnum said "There is a sucker born every minute"
......and the circus is fed but you go hungry.
Regards and caveat emptor,
Vortex1
Zeitmaschine
I find that reading stuff rather interesting: Secrets of the Aether
»The Shape of "Emptiness"«
»Aether is a dynamic fabric of space-resonance composed of independent quantum units. Each quantum unit of Aether contains three dimensions of length and two dimensions of frequency (distributed frequency is the unit of resonance). In addition, Aether also contains one dimension of mass, four dimensions of charges (two dimensions of electrostatic charge and two dimensions of electromagnetic charge), and spin. Each of the above named dimensions produce a quantum unit of rotating magnetic field.
All alternating currents also distort the Aether as the expansion and contraction of electrons occurs. Electrons can expand and contract by changing their toroidal radii. As the smaller electron radius shrinks, the larger radius grows, thus conserving the angular momentum. Nevertheless, the Aether radius (related to spherical resonance) changes with the large radius of the electron. Thus as the electron expands and contracts, so does the Aether, making it possible to modulate Aether units directly, just as Tesla proposed.«
»Not Just for Physicists«
»The Standard Model of Particle Physics describes electrons, photons, protons, neutrons, and even things like gluons and quarks as "particles." In the Aether Physics Model, these "particles" are not solid, nor are they pieces of something solid. The very basic form of physical existence is termed "primary angular momentum" when we discuss its mechanical structure. When discussing a stable form of primary angular momentum in general, we will call it "onn" (onta when plural)11. Whatever process it was that first thrust onta into existence, it is the Aether that maintains the onn spin, and accordingly the structure of all physical matter. Though it may sound counterintuitive at first, physical matter, as we know it, is actually a trace of the Aether. In other words, physical shape actually comes from non-material Aether, and is not an inherent property of matter.«
»Energy from the Aether«
»Technically, it is not possible to get energy from the Aether. This is because energy is not onta. Only photons, electrons, and protons are onta that come from the Aether into the physical realm. Nevertheless, by generating onta, and putting the onta to work, then it is possible to produce "energy from the Aether."
In the Aether Physics Model, photons are onta with an inherent velocity. Photons convert to electrons through the photoelectric effect. Thus if a device is properly constructed to generate photons from dark matter, and if a circuit that converts photons to electrons is incorporated, a steady flow of electric current can be put into motion without the need for a battery or a dynamo.«
Have to study this further...  8)
Vortex1
The book "Secrets of the Aether" stands head and shoulders above many of the other "secrets of" books out there.
I did a quick scan of it's 314 pages and found the topics very interesting. Hope to do a full read of it soon as time permits.
Thanks Zeitmaschine, much appreciated.
jbignes5
 Hello my friends!
Since everyone is talking about what I was talking about years ago I thought I would drop in and start chatting again.
Tesla has always been the answer. Looking to his writings will give you clues to the process.
One question to get the ball rolling.
What is a spark or arc? Plasma right?
The Aether is plasma and an arc or spark is plasma condensed by the high voltage.
Now lets see what plasma is exactly and how it is attracted to higher potentials.
Plasma is not the 4th state of matter but a component of matter and space itself. Plasma is displaced by matter and creates a density change of the channels of plasma within matter. Matter squeezes the plasma channels together and it causes it's potential to rise in that pinching of the plasma streams and gives rise to the intensity of matter or energy level within matter.
In my investigations into what plasma is and how it works in our solar system I have found out that Plasma flows and condensations of plasma give matter it's potential within the plasma field. Our sun is just a pinch in a great plasma flow out of the center of our Galaxy. This pinch, also called a z-pinch, is the reason for all the energy we see coming from our Sun. The pinch sprays plasma all over like a 360 degree shower head. Our own planet is nothing more then condensed plasma flowing into the pinched plasma channels within our planet. Gravity is nothing more then the plasma flowing into those channels and squirting out the end of the channel. There is a vacuum formed pulling at the plasma pooled up around our planet creating the gravity we are used to seeing on a daily basis. This is also the explanation of why there is not gravity outside of our planets atmosphere.
When plasma condenses around a high potential it will conduct and discharge twords the opposite side effectively balancing the space between the electrodes and the electrodes as well. This is done via potentials of the electrodes. When the opposite electrode gain in potential then the opposite electrode has less potential and discharges again to the lower potential.
Plasma is also magnetic sensitive. It can and will produce and channel magnetism as well. In my example of the planet we have plasma field around our planet and when it moves via the electrode analogy twords the highly negative potential it must exit the planet. It does this via the poles and what gives the poles a magnetic field based on the electric potentials present in our world. The surface of the atmosphere has a very high potential of 360k volts with the surface of the earth being the zero line and the center of our planet having a focal point that is the mirror of the 360k potential of the ionosphere. The focal point being Negative 360k.
I think Tesla figured this out and realized that an increase of plasma density has a magnifying effect on any energy traveling through or outside of matter but only in the potential realm. Meaning we will have to transform it down to get the current we are used to.
This one page of the Colorado notes describes how to use his method to get the impulses we need. Give it a look over and see if it helps.
http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes04.htm
Try to pay attention to the angles that each coil is at in reference to the secondary coils. Meaning the secondary and extra coils. Also read some way down and see why the bifilar coil was used and how it was used.
P.S. Tesla realized that if this process was hooked up in such a way that you could generate huge current flows in a central secondary like a rotor, this is coined as a rotating transformer. Also remember that the electric field grows out of a wire at 90 degree angles, radiantly. So from the surface outwards.
I have a system in mind that will self excite and loop a portion of the energy back to a cap battery pair. The cap being slightly higher when the energy flows back in. Diodes in reverse will allow charging and no feedback. The cap acts like a fast acting wave pool to feed the battery with gathered impulses. A natural wave form should automatically happen via resonance of the battery tank. when the battery is full it will auto balance and not take any impulses due to being out of resonance. Additional checks can be used via current sampling into the charge tank. A simple loop could redirect the impulses and current back to the system or radiated out via an antenna as a loss.
The drive system is a magneto or Faraday paradox generator. Once generated it will feed a disruptive discharge system into bifilar wound field coil pairs. So 4 bifilar coils around a toroid field core. Two channels need to be generated by the paradox system and then grounded through the bifilar coils to either ground through a spark gap or to a virtual ground like the body to a car.
The rotor of the generator will need to be driven around and it will have two regular solenoid coils for generation. The heavier the better (theoretical but they need to be balanced to the bifilar coils weight). Less turns and bigger gauge can make up for the difference. The rotor core needs to be grounded into an antenna with a bifilar coil at the end to act as a bigger mass end. The capacity will be raised by the design of the bifilar coil with increased capacitance allowing the excited capacitance to work in the Tesla method.. This will allow more plasma to be pulled into the system enhancing the generation and shunting the flow to the ground itself. The generator part can be enhanced further by turning the rotor in the field and generating more current in the rotor coils. This is where you take off the power as well and maybe an intermittent pull off would pressurize the magnetic field and hook it to the field cores better. This would allow the field to self balance and center itself better. Plus when the heavy magnetic field attaches to the field core it will naturally cut the field core windings and generate additional high voltage hopefully enhancing the generation even more. The field cores should be made in two halves and the Leedskalnin approach to the PMH via locking coils on each end of the halves of cores. This way one could use a clam shell as a case and it would be very easy to maintain as well and magnetically lock via energizing the PMH. or simple pressure when locking the case could be sufficient if the PMH addition will not work due to the magnetics in the system.
You can use a regular induction motor 4 pole to run the entire system running off of the current you are generating. All of this can be put onto one shaft and then the shaft should be grounded as well. I am thinking that if the shaft is grounded to the antenna then it will enhance the plasma around the antenna and a better current flow will happen, Still highly theoretical as of yet..
I will be working on the system soon and when I am happy with the results then I'll post it up.. Right now I am not in the position to work on it that much. I might be making another move real soon because of family matters. I'll keep you posted.
I will be trying this on a very small scale. I am using garden wire that is just steel as the core. A coil in itself. We will see what happens. With the holidays coming up fast I think my chances of getting much work done on this is sllim to none. But we will see..
