Quote from: voidI can speculate
all sorts of things about you TK, but if I assert that you are using tricks in some of your videos or that you are in cahoots
with some one then I think most reasonable people anyway would expect some actual evidence to be presented. :D
Does this all really need to be pointed out? Strangely, apparently it does. ;)
All the best...
Well.... except for some of the alt.snakeoil spoofs there is no trickery in any of my videos, and I can do anything you like in order to prove it to you. Even sending you the actual apparatus if you really need that to happen to be convinced. Contrast that with what you get from Akula or Ruslan. Does this really need to be pointed out? Apparently it does.
Do you believe cheeseburgers can be pulled out of walls too? Because that is, to me, just as believable as what Akula ............... and Ruslan..................and Stivep.................. have shown in the videos.  There, did I separate them enough in my speculation for you?
And I don't accept your "explanation" of the waveform issue. I have faith that if I build a device according to a posted schematic and it produces identical waveforms as someone else's device, it should also perform the same in every respect that really matters. To accept your explanation, one would have to accept that he has pulled a "bait and switch" deception, demonstrating a different device "self running" than the one that made the waveforms and was built according to the schematic. If you accept this kind of deception as being possible, why do you not also accept that he could simply be faking the whole thing? Don't forget about Occam's Razor. And also.... 50 volts per division! When it clearly isn't!
MarkE
Quote from: Vortex1 on February 06, 2015, 09:23:22 AM
From TK post #991
TK
Regarding your post #991, I'm not sure from reading if your irritation is at me (kill the messenger) or EMJ. I think part of the problem is that there are two forums where I post, here and at OUR (as user ION).
At OUR, I directly asked Chris for a parts list and schematic that produced the scope shots he posted, because the scope shots did not make sense to me (as a professional designer of electronic power control circuits for over 40 years). It was at that point he revealed that he was using a deflection transistor directly driven from a Function Generator. Then the scope shots made sense. The transistor was starved for current, so went into current limit mode as I pointed out in the annotations of EMJ's scope shots.
I also posted what I could on this forum, but as usual there were very few replies or comments from the "good old boys" here. I sometimes wonder about that (but not much).
If EMJ were operating in professional mode, he would have produced exact test results that coincided with the exact schematic and exact parts list at the outset. We can agree on that.
I have often made many comments regarding unprofessional activity by members posting at OUR. One of my main complaints is that claimants never produce a document with all parts, schematics, scope shots circuit detailed explanation and claims in one place, not spread through numerous posts with changes added. Changes should create document revisions.
In the future, I hope it would be incumbent on EMJ (and other claimants) to provide such a document at the outset for reference and to avoid pages of confusion.
Regarding your last line:
Since you were referencing my prior post *989 in your reply, I can only surmise the question is directed to/at me. Bad form to quote me in the post and then infer that I can answer this last question (with such rancor). Don't you think it is up to EMJ to answer that question? AFAIK he is using a NTE2331 equivalent to the 2SD1555.
PIH asked for the specific part numbers used  here and EMJ told him that he was "greedy" and to take a hike.  EMJ has been taking something other than a hike.
MarkE
Quote from: Void on February 06, 2015, 10:14:45 AM
Hi TK. You have made some misleading statements above, so just want to correct a few things.
Akula, Ruslan, and Stivep are not some group which work together.
Stivep has previously translated some of Akula's videos, and apparently has communicated with Akula a bit, but apparently is otherwise not connected with Akula.
Ruslan has said he has not communicated with Akula, I believe, but has been doing some replication experiments with some devices that Akula has shown in his videos.
It is quite suspicious that Akula could have made so many different types of devices self running;  however, to my knowledge, no one has ever shown any
convincing evidence that Akula actually is using any trickery. It seems that any talk of Akula using tricks is just speculation at this point.
Akula has demonstrated at least a couple of devices up close to a few different people at his house, for which some videos were posted, and Akula has also
demonstrated some of his devices to various people in Germany. There are some indications that Akula may possibly have already made some money on some of
his devices. Ruslan has recently released some schematics relating to the Akula replications he is doing, but some of Ruslan's statements about his
devices seems to contain conflicting info with other things he has said, but as of yet no one has shown any convincing evidence that Ruslan is
using tricks as well.
Akula may be doping his ferrite cores with a radioactive substance for all I know,  or he may be using various simple tricks, but, again,
as of yet no one has detected such tricks, that I am aware of. If anyone gets a chance to view one of Akula's or Ruslan's devices in person,
besides looking for the obvious such as hidden batteries, or hidden wires, or hidden wireless power sources, you may also want to bring
along a Geiger counter to see if you can pick up any unusual amounts of radiation coming from these devices :) For sure it is
suspicious that Akula has had so many different self running devices, I won't disagree with that. Ruslan's stuff is also
suspicious in that Ruslan has made videos showing much of how his devices are supposedly assembled, although he has
left out some important details such as exactly how he tunes things, and left out some specific circuit details, but no one as of yet has been
able to replicate what Ruslan is doing. Also because Ruslan's statements sometimes seem to conflict in some ways with what he actually shows
in some of his demo videos, this adds more suspicion to Ruslan's stuff as well.
It goes without saying that any claimed self running over unity device could well be using tricks of one sort or another,
but until someone actually shows some convincing evidence of such tricks for any given person, it is of course just speculation. :)
All the best...
When replications of the supposed circuits used fail to reproduce the miracle, it's a pretty safe bet that the miracle isn't what it is represented to be.  The burden of proof is always on the claimant.
kEhYo77
or a replication was't a REAL replication at all...
conradelektro
I did some tests today with the mono audio amplifier. Attached please see the test circuit and a photo of the set up.
The test involved first a 100 Ohm resistor R1 in series with the primary and then (as a control measurement) with a 10 Ohm resister R1 in series with the primary. There is only abut 10 mA flowing through the primary, therefore one can do it with a R1 = 10 Ohm or R1 = 100 Ohm.
Parallel with the secondary was always a 100 Ohm resistor R2.
Input:
200 mVpp 600 Hz sine from function generator
12 V ~30 mA idle, ~40 mA with load from power supply:
Va = 3.68
Vp = 2.48
R1 = 100 Ohm
I = (Va - Vp) / R1 = (3.68 - 2.48) / 100 = 0.012
Watt through primary = I * Vp = 0.012 * 2.48 = 29 mW
Output:
Vo = 0.136
R2 = 10 Ohm
Io = Vo / R2 = 0.136  / 10 = 0.0136
Watt through secondary or R2 = Io * Vo = 0.136 * 0.0136 = 1.8 mW
Input:
Va = 3.36
Vp = 3.28
R1 = 10 Ohm
I = (Va - Vp) / R1 = (3.36 - 3.28) / 10 = 0.008
Watt through primary = I * Vp = 0.008 * 3.28 = 26 mW
Output:
Vo = 0.176
R2 = 10 Ohm
Io = Vo / R2 = 0.176  / 10 = 0.0176
Watt through secondary or R2 = Io * Vo = 0.176 * 0.0176 = 3 mW
It looks like the primary has a very high impedance (at 600 Hz) if the partnered secondary coils are "bucking". It will therefore be possible to drive the primary without a resistor R1.
There was little phase shift in the primary and in the secondary about 25°.
@MileHigh: I was mistaken, the Voltage over the primary and over R1 was not the same. The Voltage over R1 was very small (Va ~ Vp). But feeding 12 Volt to the audio amp made the small difference of ~80 mV visible.
Greetings, Conrad
