0 Members and 46 Guests are viewing this topic.
EMJunkie
Quote from: John.K1 on February 07, 2015, 04:21:14 PM
EMJunkie- I am getting the same hissing noise  from my Brovin kacher - two coils in attraction mode -on ferite bar -  I am pretty sure it has to do with the feromagnetic resonance ;) But you never know.
Hi John, yes sounds like a different setup. Brovin Katcher typically has no Opposing Fields?
  Chris
EMJunkie
Quote from: MileHigh on February 07, 2015, 04:26:51 PM
Well in one clip he mentions his coil is experiencing high-voltage internal arcing problems.  Would that be the noise he is talking about?  If it is, then it just goes back to my previous posting.  The coil is generating high voltage, and the air between the windings is arcing, effectively undergoing a dielectric breakdown.  Same old story one more time.
Hey MileHigh, I don't doubt these effects, I have seen many already, but this is different.
Opposing Fields, I don't like the term, but "Bucking" will do what?
Not make Cheese Cake? They "Buck" and what could the "Bucking" do?
***   Even Vortex/ION said it, the Spike is due to Leakage Inductance! I said this right from Day One!
  Chris
John.K1
Quote from: EMJunkie on February 07, 2015, 04:40:11 PM
  Chris
Yep, you can oppose the field as you like :)  Also I have a bunch of small ferite rods and bars and I do build different structures around my set-up- including some Neo-magnets. Funny was today the hissing sound started to rise-up to the level of ultra sound- must say I did a step back as I didn't know if this will not generate some sort of lightning :) But it takes oly  2.4V @ 0.4A  - on the colector around 250Vpp.
Farmhand
Does the ringing do anything or not ? That's the question really.
If the ringing is causing some crazy high intensity current flow through the load then it could still be useful even if less than
100% efficient.
Getting a Huge/High Amplitude ringing is all well and good but.
1) Does the HA ringing affect the load ?
2) Does the HA ringing cause a high intensity current through the load ?
3) Is the HA ringing associated with "Extra energy" from the output ?
If no extra energy then what is the actual benefit of doing it ?
Maybe it's just me but if I seen that in my circuit and it wasn't doing anything special then I would want it gone.
The real meaningful things are the real power/Energy input compared to the real power/Energy useful output, or
if the setup does something useful.
Or to say it with less words. What matters is the real/total/true efficiency to power the load, or if the setup can do something
useful and I guess novel.
