0 Members and 158 Guests are viewing this topic.
EMJunkie
MarkE and Poynty Pants, I agree. This is critical to all doing measurements. Measurement error is a fact of life. Its unavoidable for all, even though those with very expensive equipment are not immune from these measurement errors.
You know, I have said from my early days, the only real way to show OU is a Self Runner ;)
These days, even this is not enough, so many will immediately say: "HOAX" - Sad but true.  :'(
All I can say, is think Magnetic Oscillator, How can we make a Magnetic Field Oscillate in proximity to Well Thought Out Coil Configuration.  ;)
I have been showing this for some 5 Years now and only a few have caught on.
MarkE
Quote from: EMJunkie on February 09, 2015, 08:22:09 PM
John, I wonder if you have seen this video: https://www.youtube.com/watch?v=iJsVSMQqCOM
Can you see the Implications here?
The implications are that you are unfamiliar with concepts such as:  power division, impedance matching, and shunt paths.
Can you see what really is going on here?
For all your appropriate respect for Dr. Feynman you are going the opposite way:  inventing complexity to replace simplicity.
Do you know what this means to be able to achieve results like these?
The results are obtained trivially.  They do not suggest, nor do they lead to OU.  As in your examples, decoupled input / output power is readily achieved by starting with very bad efficiency.  The higher the efficiency, the more tightly coupled the input and output.  Dissipative regulators:  series and shunt throw away power in order to decouple the input and output and thus attain regulation of one or the other.  Efficient switching regulators tightly couple the regulated side to the unregulated side.[/quote]
My rabbits are running all around the Smart People here, its just that the Holland Duell's are blind to these Electrified Rabbits  ;D[/quote]Holland Duell was an esteemed and accomplished individual.   I don't know what you have running around your house, but you might want to double check their gray coloration and long tails against your idea of rabbit.
When I do show the next step, it will show the extreme simplicity, and what's more the Holland Duell's will still dispute it, ah its well known, just a noisy environment!! Hahaha it works best with a sine wave on the input, so Noisy environment is not even in it.
It is truly amazing that you continue to invoke Mr. Duell's esteemed name as though it is some sort of insult.  What you will not be showing is average output power even approaching average input power, much less a COP > 1.
Again, my posts will only show whats been shown before, just not explained before. It is so extremely simple that all will kick themselves!
You have repeatedly chosen to ignore the explanations and replications based on those explanations.
I already have given it all, its just no one has put it together yet.   ;)
  Chris
MarkE
Quote from: EMJunkie on February 09, 2015, 08:58:03 PM
If you believe that you have had provable OU for five years but are still trying to establish credible evidence then you are very confused about something.
From the Description in EMJ's video linked above:
QuoteThis can be improved hugely and is possible to be made to self run with this technology.
The video was posted in July of 2011. So where is the self-runner made with this technology? Nowhere, that's where, and the claim is simply false.
In the video he states that there is no change in input power when the load is connected/disconnected, and he shows the power supply's ammeter fluctuating by 100 mA as he is making that statement! At 12.6 V, that corresponds to over a full Watt of fluctuation in input power, and he is showing a tiny flashlight-type bulb as the  load.  The bulb is rated at a bit over 3 Watts and the power supply is fluctuating by at least a third of that power. Finally he notices that the psu is indeed fluctuating and backs up and admits it.
"Self assisted oscillation"? He's feeding a sine wave from a function generator amplified by an audio amplifier into a coil set! And varying the coupling and mutual inductance by shorting and unshorting a coil wrapped around the core assembly. Where is the "self assisted" part of that?
EMJ, Richard Feynman would laugh at you if he could see the use you are making of his lectures.
EMJunkie
Quote from: MarkE on February 09, 2015, 09:01:08 PM
Oh MarkE - I am not trying to "establish credible evidence" for anything! I don't care what you think  ;)
In-fact, I am trying to do something, and what I am trying to do, is get people thinking!
This has already started happening. Its been happening for many years now.
The most simple techniques, already known, well known for some 100+ Years, applied simply, constructively, to do something that is beneficial for all of Humanity.
Solid State Electrical Energy "Generation" that can be achieved at a very low input power to start the Prime Mover. Then, it will Run Itself.
But don't feel bad, you will catch onto it one day. After the rest of the world does.
Can you Imagine how simple this is to do? I bet you're really frustrated!   :)
Another little hint, Some Motor/Generator's can speed up under load, Why and How?
  Chris
