0 Members and 44 Guests are viewing this topic.
EMJunkie
Quote from: synchro1 on February 10, 2015, 09:01:51 PM
@EMJunkie,
I did some experiments with this effect and can assure you and everyone else that the oscillating magnets always slow down and stop. These guys have done a pretty good job of making you look like a faker. I'm tending to be convinced they're right.
@Synchro1,
Have they, well it is after all their job and they have had a ton of practice.
Magnets do not Oscillate! Never will!!!
Coils in close proximity to a Magnetic Field can!
Its called the Inverse Square Law. Earnshaw's Theorem predicts it! Also shows situations where it can happen.
The Hydraulic Ram Pump works the same way! Inverse Square Law.
Think what you will!
Once those, that do think I am fake, or what ever, once they do full circle and exhaust all other possibilities, then they come back to this, what I have brought forth, they will feel like fools!
There is much more than sufficient evidence to say that this area contains a ton of supporting results and evidence to show that more than just a few little effects exist.
Void's results are very good! Look at them!
Poynty99 and his spoiled brat antics, MarkE and his Childish villainy, these idiots are just a few out of hundreds, many others are looking at and searching this area. Just because two Brainless, temper tantrum morons have a hissy fit because they want it all now, and cant because I will do what I think is best for all, not for those brain dead morons, can not get the better of me, of what people have started looking at.
It is a Magnetic Field that Separates Charge.
Its a Magnetic Field that's produced when Charge Flows.
I have pointed out, continually, the most basic of known principals, all of which are employed every day in the Electrical "Generators" that supply Power to your homes and Businesses, this is where people need to Start.
You know what, many told me not to come forward because of exactly what I have experienced. I wish I didn't now to be honest. So many people are so stuck in their ways.
Some are just Idiots! I am happy to see that this is a minority!
Cap-Z-ro
Beware of those who make definitive claims relating to magnetic fields...no one fully understands the nature of magnetism.
Anyone who claims otherwise is out to discourage efforts in that area.
Regards...
MarkE
Quote from: Bob Smith on February 10, 2015, 09:30:00 PM
I have a number of relays at my disposal - the cheaper, at-hand choice.
Will give it a shot when I get time.
Bob
Whatever works.  You can also get bobbins and cores of your choice very cheaply.  When all is said and done you will find out what people who have been making transformers for over 100 years have known the entire time.
MarkE
Quote from: EMJunkie on February 10, 2015, 09:42:31 PM
@Synchro1,
No amount of shrill carnival barking will make your false claims true.
EMJunkie
Repost:
Hi Jean!
Hahaha I also do some Programming, takes some clever thinking to achieve goals when Programming.
Schematic's are open to interpretation when looking at coils like these. Very hard to draw and get the idea across. It will either work or not work.
Approximately 99% of all Electro Motive Force is Countered by Lenz's Law. If we were to reduce Lenz's Law by 10% this may give us Unity. 20% 110 OU......
Lenz's Law is a Reflected Magnetic Field. Directly the result of Current Flow.
Working with the Magnetic, as long as one can show Charge Separation at the same time, will led to possibilities where the Magnetic Field Component can be localised, and yet not reflect back on the primary.
It is easy to see such effects, once one Loads the Secondary, the primary current will either not change, or reduce.
All devices have losses, this is unavoidable. The idea is to recoup these losses and some for a useful output.
I have found and shown 2 Coil Configurations that can be beneficial. It just so happens that I stumbled onto these configurations, before realising the History behind them.
Electrical Energy all comes from the same place.
No new Science is needed!
Energy is Matter, Charge Separation via Magnetic Force, the Lorentz Force is how Energy is brought forth to terminals.
It is Lenz's Law that confines one to a reduced Output, and it is "Partnered Output Coils" aka "Bucking" Coils that are the key to reducing Lenz Law.
1: Separate your Charge Carriers (Ion's and Electrons)
2: Draw by use of Reduced Lenz's Law Effects - Don't kill the source!!!
3: The end result can be OU if Lenz's Law is reduced enough.
Plain, Simple, right smack in the face of all.
So many can not think simply anymore, their brains seem over complicate things.
Nice Work Jean  Wink
One example of such use:
