0 Members and 65 Guests are viewing this topic.
allcanadian
Hello Chris
QuoteOld People sitting at Home, "Thought Experimenting" are not really something I wish to put my future in...
You see in my post I didn't really want to go there and believe me I considered it, the old thing, but there may have been a Kreskin effect going on and if you understand what Kreskin actually means then.... yes your old, lol.
AC
EMJunkie
Quote from: MarkE on April 20, 2015, 10:36:55 PM
You still do not seem to graps the fact that Lenz's Law refers only to the orientation of induced voltage.  It is Faraday's Law of induction that describes the circumstances under which induction occurs.  And it occurs independently of whether one has one wire/coil, two, or twenty five, and independently of how they are oriented and/or wired together.
MarkE - I think this is time for another OMG! You have proven yet again that you don't know what you're talking about.
I am trying to be Kind and Gentle with you here. In all your genius, you simply don't know what you're talking about!
Ref: http://en.wikipedia.org/wiki/Electromagnetic_induction
Electromagnetic induction was first discovered by Michael Faraday, who made his discovery public in 1831.[2][3] It was discovered independently by Joseph Henry in 1832.[4][5]
In Faraday's first experimental demonstration (August 29, 1831), he wrapped two wires around opposite sides of an iron ring or "torus" (an arrangement similar to a modern toroidal transformer). [6] Based on his assessment of recently discovered properties of electromagnets, he expected that when current started to flow in one wire, a sort of wave would travel through the ring and cause some electrical effect on the opposite side. He plugged one wire into a galvanometer, and watched it as he connected the other wire to a battery. Indeed, he saw a transient current (which he called a "wave of electricity") when he connected the wire to the battery, and another when he disconnected it.[7] This induction was due to the change in magnetic flux that occurred when the battery was connected and disconnected.[1] Within two months, Faraday found several other manifestations of electromagnetic induction. For example, he saw transient currents when he quickly slid a bar magnet in and out of a coil of wires, and he generated a steady (DC) current by rotating a copper disk near the bar magnet with a sliding electrical lead ("Faraday's disk").[8]
Faraday explained electromagnetic induction using a concept he called lines of force. However, scientists at the time widely rejected his theoretical ideas, mainly because they were not formulated mathematically.[9] An exception was Maxwell, who used Faraday's ideas as the basis of his quantitative electromagnetic theory.[9][10][11] In Maxwell's model, the time varying aspect of electromagnetic induction is expressed as a differential equation which Oliver Heaviside referred to as Faraday's law even though it is slightly different from Faraday's original formulation and does not describe motional EMF. Heaviside's version (see Maxwell–Faraday equation below) is the form recognized today in the group of equations known as Maxwell's equations.
Heinrich Lenz formulated the law named after him in 1834, to describe the "flux through the circuit". Lenz's law gives the direction of the induced EMF and current resulting from electromagnetic induction (elaborated upon in the examples below).
Following the understanding brought by these laws, many kinds of device employing magnetic induction have been invented.
As is pointed out above, Lenz Law is simply the Negative Sign in Induction. It is simply a Reflected Magnetic Field back on the Primary Magnetic Field.
Ref: http://en.wikipedia.org/wiki/Heinrich_Lenz
Heinrich Friedrich Emil Lenz (Russian: Эмилий Христианович Ленц) (12 February 1804 – 10 February 1865) was a Russian physicist of Baltic German ethnicity. He is most noted for formulating Lenz's law in electrodynamics in 1833. The symbol L, conventionally representing inductance, is chosen in his honor.[1]
Lenz was born in Dorpat (nowadays Tartu, Estonia), at that time the Governorate of Livonia in the Russian Empire. After completing his secondary education in 1820, Lenz studied chemistry and physics at the University of Dorpat.[2] He traveled with the navigator Otto von Kotzebue on his third expedition around the world from 1823 to 1826. On the voyage Lenz studied climatic conditions and the physical properties of seawater. The results have been published in "Memoirs of the St. Petersburg Academy of Sciences" (1831).
After the voyage, Lenz began working at the University of St. Petersburg, Russia, where he later served as the Dean of Mathematics and Physics from 1840 to 1863 and was Rector from 1863 until his death in 1865. Lenz also taught at the Petrischule in 1830 and 1831, and at the Mikhailovskaya Artillery Academy.
Lenz had begun studying electromagnetism in 1831. Besides the law named in his honor, Lenz also independently discovered Joule's law in 1842; to honor his efforts on the problem, it is also given the name the "Joule–Lenz law," named also for James Prescott Joule.
Lenz eagerly participated in development of the electroplating technology, invented by his friend and colleague Moritz von Jacobi. In 1839, Lenz produced several medallions using electrotyping. Along with the electrotyped relief produced by Jacobi the same year, these were the first instances of galvanoplastic sculpture.[3]
Lenz died in Rome, after suffering from a stroke.
Ref: http://en.wikiversity.org/wiki/Lenz's_law
Lenz's Law is one consequence of the principle of conservation of energy. To understand why, consider a permanent magnet that is moved towards the face of a closed loop of wire (eg. a coil or solenoid). An electric current is induced in the wire, because the electrons within it are subjected to an increasing magnetic field as the magnet gets closer and this produces an emf (Electromotive Force) that acts upon them. The direction of the induced current will depend on whether it is the north pole or the south pole of the magnet that is approaching: an approaching north pole will produce an anti-clockwise current (from the perspective of the magnet) while an approaching south pole will produce a clockwise current.
To understand the implications for conservation of energy, suppose that the above description was not true and that the induced currents were produced in the opposite directions to those described. Then, for example, the north pole of an approaching magnet would induce a south pole in the nearest face of the loop. The attractive force between them would accelerate the magnet's approach, and this would make the magnetic field increase more quickly. This would increase the current in the loop, which would produce a stronger induced magnetic field, a bigger force of attraction, yet more acceleration, and so on. Both the kinetic energy of the magnet and the rate of energy dissipation in the loop (due to Joule heating) would increase. A small energy input, to move the magnet forward, would produce a large energy output, which clearly violates the law of conservation of energy.
The above scenario is only one example of electromagnetic induction. Lenz's Law ensures that all induced currents have magnetic fields that oppose the change that induces them.
See electromagnetic induction and Maxwell's equations for a more rigorous mathematical treatment.
I think you really need to polish up on your High School Physics before you make your self look silly again!
   Chris
Chris:
Based on past and present experience, anything you and your private group would present would be blown out of the water by MarkE and many others.
Go ahead, just polish up a presentation and put it into a pdf and share it publicly.
Quote from: EMJunkie on April 20, 2015, 11:48:40 PM
MileHigh, we have debated for months.... Unfortunately a "Thought Experiment" is never going to solve the worlds Problems.
   Chris
My generation gave you the PC and transformed the world.
Somebody very famous from an earlier generation said, "Some chicken, some neck."
EMJunkie
Quote from: allcanadian on April 20, 2015, 11:39:03 PM
In any case there seems to be more and more people making claims, more and more people who seem to be doing quite remarkable things. As such I do not think it will be long before you will have your proof. It's called the "exponential growth of knowledge" and it's it waits for no man.
AC, I have, sometime ago, made my mind up. Proof can always be disputed, no matter what evidence is presented. I could do one video, 100 videos or a million videos, many would dispute no matter what.... There is always something that will be the subject of debate. A cheap meter, too close to the Radio Station, Still presently on Earth, the list of ridiculous excuses goes on and on...
Some will go to their grave still with Eyes Closed!
How many years after Humans Flew did people not believe it? Humans cant Fly! hahaha
MarkE, MileHigh, Fell off the edge of the Earth Lately? Careful you're getting close again.
Please, let me ask you, if a Standard Generator was not subject to Lenz's Law, would it be a Perpetual Energy Machine?
I know the answer!
   Chris
