0 Members and 185 Guests are viewing this topic.
EMJunkie
Quote from: MarkE on April 23, 2015, 06:12:52 PM
More ad hominem attacks.  More snooze-ville.Imagine that, standard coil winding formulas work.  The document simply repeats what any coil winder has known since the late 1800s and has used to scale the voltage for solenoids, DC motors and such since then.And you offer up yet more ad hominem attacks.
MarkE,
Because you're too tired to actually read the data and report back on facts: "The results shown above indicate that four times more current can be used to generate a magnetic field with mirror image symmetry winding techniques."
Now, does this make you a reliable person that reports real data truthfully? No it doesn't, its makes you untrustworthy and foolish...
I did say in my results, 3 Magnitudes of order more than a simple conventional Coil....
MarkE!!! Yet another OMG (Oh My God for you retiree's)  Yet again, you've proven to be just a Fool!!! I thought you were supposed to be smart???
MarkE
Quote from: John.K1 on April 23, 2015, 06:04:04 PM
Mark, I have done some translation of the document , where some guy mathematically proves the higher efficiency of the resonant motor and transformer etc.  I need to find it and I would appreciate if you take a look at it and tell me what you think about it.
Resonance is not a factor in the operation of the Orbo motor presented at Waterways.  The motor exhibits very little torque as exemplified by the very long acceleration time constant under the no load conditions under which it was always run.  The "solid state Orbo" was a transformer inefficiently operated and ineptly measured.  Steorn claim that the transformer was their inspiration for the insipidly stupid Hepha-Heat water heater.
MarkE
Quote from: John.K1 on April 23, 2015, 05:59:04 PM
Hi Chris,
" TK, youre an Idiot in all senses of the word!"   :D
Ok ,Lets test him :D ... the picture below.
I am just wondering, you said before it works better with the core.  Did you actually meant split core in the middle?
Thanks,
Peace,
PS: TK  take it easy ;)
The first two lines in that jpg don't mean anything because there is no operator connecting them to each other or the bottom line.  The bottom line sums to 2.
MarkE
Quote from: EMJunkie on April 23, 2015, 06:20:48 PM
MarkE,
Coil winders have known for over 100 years that given a fixed window area, to a close approximation that window can be divided into n turns of wire that will each have an average length of 2pi times the window center diameter.  Slice it dice it anyway that you want and for a fixed window you scale the magnetic field as n*I, and resistance and inductance as n2.  Consequently, a transformer or solenoid or DC motor has a nearly constant power loss at a given field strength.  Changing the number of turns n changes the working voltage that is appropriate for the winding.
I see more ad hominem attacks.
You've said many false things.
And thee are more ad hominem attacks.
MarkE
Edit1:  Here is the Impulse LC oscilator document.
That document is an EE101 fail.  Reactive power is not real power.
