0 Members and 133 Guests are viewing this topic.
EMJunkie
Quote from: John.K1 on April 24, 2015, 03:02:37 AM
Is the conventional physics as we know a last stop?   NO ;)   http://newsoffice.mit.edu/2015/self-accelerating-particles-0120
"The electron is gaining speed, getting faster and faster," Kaminer says. "It looks impossible. You don't expect physics to allow this to happen."
JK1 - I agree. Physics is mostly right, its got holes. Physics just needs a tickle up and a bit of a correction. From people with minds that can be accepting to make the necessary corrections. Its really not Physics that has the Issue, its the Textbook Morons behind it. Many now accept it, many are working to Fix Physics! Like you have pointed out!
  Chris
EMJunkie
Enjoykin!!! Very impressive!!!
URL: https://www.youtube.com/watch?v=bxWuo2GCkrQ
Wow! 4x AAA boiling 4 Litres of Water in 11 Minutes!!! WOW I am impressed!
Thank You!
   Chris
EMJunkie
I would like to point out again, my work is backed up by Engineers, the Trolls here are wrong! This Technology is REAL All day long, every day.
I wish to quote: http://www.padrak.com/ine/KOENIG.html
Think Power Generation or using this as a prime mover!
THE USE OF MIRROR IMAGE SYMMETRY IN COIL WINDING,
APPLICATIONS AND ADVANTAGES IN MAGNETIC FIELD GENERATION
For full details and drawings, refer to the Proceedings of the 27th Intersociety Energy Conversion Engineering Conference (IECEC-92 San Diego, CA August 3-7, 1992, P-259, Vol 4, pp 4.311- 4.313); or request a copy of Fulcrum Vol. No. 1, April 1992, from the University Of Science And Philosophy, PO Box 520, Waynesboro, VA 22980, phone: 1-800-882-5683.
ABSTRACT
An improved method of winding inductors, transformers and motors has been discovered. This invention greatly enhances the ability to generate magnetic fields with a given amount of wire. This invention is as fundamental to the use of magnetic fields as was Nikola Tesla's use of rotating magnetic fields for the generation of alternating current.
The mirror image symmetry of winding coils is achieved by winding two strands of wire onto a coil form at the same time. This method results in two coils each occupying half of the form. The set of coils is then connected in parallel. When the coils are connected as described above, the net result is the ability to generate many times the magnetic field within and around the Solenoid.
This invention has a wide range of applications in transformer, motor, generator, and loudspeaker design. This paper will detail the results of tests performed with solenoids. Magnetic field strength has been measured and will be shown to be substantially increased using mirror image symmetry.
INTRODUCTION
Earl Koenig's Mirror Image Symmetry
U.S. Patent 4,806,834
An improved method of winding inductors, transformers and motors has been discovered by Earl Koenig of Averill Park N.Y. This invention greatly enhances the ability to generate magnetic fields within a given space and with a given amount of wire. This invention is as fundamental to the use of magnetic fields as was Nikola Tesla's use of rotating magnetic fields for the generation of alternating current. The mirror image symmetry of winding coils is achieved by winding two strands of wire onto a coil form at the same time.
BACKGROUND
In order to visualize this process, imagine a cylindrical coil form. As the form is turned, wire is wound simultaneously onto the form starting from each end. The wires are wound until they meet in the center of the coil form. Here the wires are connected to form one terminal of the circuit. The wires at the opposite ends of the form are connected to form the other terminal of the circuit. The result is a set of coils connected in parallel on a common form. More windings can be added, if rather than connecting the coils when they meet in the center, the wires are wound back over the form toward the ends where the respective windings originated. This results in two coils each occupying half of the form. When the coils are connected as described above, in parallel fashion, the net result is the ability to generate many times the magnetic field within and around the Solenoid.
Definitions:
Mirror Image
1. An object having a spatial arrangement that corresponds to that of another object except that the right to left sense on one object corresponds to the left to right sense on the other.
2. An image of an object, plan , person, etc as it would appear if viewed in a mirror, with right and left reversed.
Symmetry
1. Correspondence in size, shape and reletive position of parts on opposaite sides of a dividing line.
Mirror Image Symmetry:
1. A condition midway so divided so that equal portions simultaneously separate in opposite directions as viewed from the neutral location between each half section.
TEST RESULTS
We have tested this design using two identical Guardian 11 HD INT 12VDC solenoids. One solenoid was re wound using mirror image symmetry and the same wire that came on the solenoid. The performance of the solenoid using the mirror image symmetry is outstanding, far beyond the solenoid using conventional windings.
                                     Resistance Inductance    Current         Gauss   Force
                                       (ohms)     (mH)    (Amps @ 5VDC) @ 5VDC   (gms)
Mirror Image Symmetry        2.0       1.08               2.45           121.2    340
Standard Winding                 7.3       4.28               0.68            58.5     169
The results shown above indicate that four times more current can be used to generate a magnetic field with mirror image symmetry winding techniques.
The measured value of magnetic field of the mirror image symmetry configuration, measured at the center of the ends of the solenoid, is double that of the standard winding. The force available with a plunger in the solenoid was also measured to be twice that of the standard configuration.
Another way of looking at the results is to consider the economic advantages of using mirror image symmetry. The data suggest that a device wound with mirror image symmetry can produce the same effects with a greatly reduced amount of wire in a smaller package or produce a device with twice the power in the same size package as currenty available.
I think the "Intersociety Energy Conversion Engineering Conference" and the "University Of Science And Philosophy" is a fair bit more important and trustworthy than the Four Stooges here!!!
All the Best
  Chris
MarkE
Putting 4X current through 2/7.3X resistance yields power dissipation of 32/7.3, or greater than 4X as before while the operating force doubled.  IOW, the efficiency fell in half and the solenoid will burn up its insulation.  If driven with the voltage scaled for constant power loss:  V = 5 * (2/7.3)0.5, then the force and power dissipation would have remained essentially constant.  IOW, the "innovation" offers no improvement in the actual usable capability of the solenoid.  One could have driven the original winding at 10V yielding 2X current and gotten the same 340g force and had the same 4X power dissipation all without ever touching any of the windings.   All the author has managed to do is overdrive the solenoid.
It does not bode well that you don't seem to understand that.
Quote from: MarkE on April 24, 2015, 06:43:55 AM
Indeed.  Referencing useless papers for clowns written by clowns.
This is all I had to read to smell junk, "This invention greatly enhances the ability to generate magnetic fields with a given amount of wire."
Yeah, sure.  You exposed Junkie for his total lack of analytical skills to distinguish junk from crap from the real thing.
Electronics wannabe goobers unaware of their own severe limitations blissfully gobbling up junk like so many sweet jellybeans.
I don't have high expectations for the "research team."
