0 Members and 187 Guests are viewing this topic.
EMJunkie
Where the Poles, (- Signs) of each field, will look something like this:
EMJunkie
So why would anyone want to do this? What benefit would there be if one were to do this?
Well?
Why?
MarkE
Quote from: EMJunkie on April 25, 2015, 11:38:35 PM
The obvious:
Induction, Lenz's Law (the -) is a Changing Magnetic Field in Time!
Wrong.
EMF, Lenz's Law, once a Current Flows, is a Changing Magnetic Field, which is the first requirement of Induction....
Wrong again.
It is well known by engineers, when the Transformer is loaded, there is a NET ZERO Magnetic Field. This means the Ampere Turns on the primary are equal but opposite to the Ampere Turns on the secondary, or close to it. Each Magnetic Field Opposes the other at any point in time. See Coil One, opposes Coil Two:
Wrong again.  The magnetic field builds in the primary and the transformer core as long as voltage of one polarity is applied to the primary.  Secondary flux NEVER CANCELS primary magnetizing flux in any transformer.  Magnetizing flux can only be canceled by actively driving another winding.
In a transformer configured to operate in the forward mode, such as a mains to low voltage line transformer, flux that results from secondary current flow opposes primary flux.  If the coupling factor were a perfect 1.0 secondary current would not cause any increase in net flux over and above the primary magnetizing flux.  Coupling is never 1.0 and so secondary flux always results in a net increase of flux over and above the primary magnetizing flux.
In a transfomer configured to operate in the flyback mode such as is used in millions of power converters daily, the secondary flux does not cancel primary flux at all.
EMJunkie
MARKE!!!!
What is dt?
Delta Time!!!!
Youre really just more than wrong this time!!! Now the readers here can see how wrong you are!!!
       Hahahaha Caught with your pants down old fella!!!
EMF = (-)dPhi/dt
Where:
    dPhi is Delta Flux
    dt is Delta Time
    EMF is the Electro Motive Force
GOON Squad Fail Moron!!! Wow what an embarrassment!!!
MarkE
Quote from: EMJunkie on April 26, 2015, 03:00:11 AM
MARKE!!!!
What is dt?
Delta Time!!!!
EMF = (-)dPhi/dt
Where:
    dPhi is Delta Flux
    dt is Delta Time
EMJ it is not as though there aren't literally thousands of good references on the net that you can simply copy.  For a person who likes to play with windings, it is rather shocking that you assert that assert a formula for induced EMF that is independent of the number of turns.  Is that what you really believe?  I suppose we can just chalk that up to your incorrect assertion that:
QuoteIt is well known by engineers, when the Transformer is loaded, there is a NET ZERO Magnetic Field.
The very thing that you emphasize is as I just pointed out completely wrong.
This is not unlike your posting of Koenig's happless "Mirror Image Symmetry" paper as support for your "partnered coil" ideas when his own test results refute your claims.
