MarkE
EMJ has not seen fit to change his wrong answers.  Here is the solution for I1 at 2s.  Our resident "partnered coil" enthusiast was in several days unable to come up with an answer or even an approach towards obtaining an answer that is even remotely close to reality.
EMJunkie
Quote from: MileHigh on May 04, 2015, 12:13:29 AM
Anyway, it's not critical.  The main point being that the "R" is the resistance of the total circuit path.  Trying to eyeball a graph where there are five subdivisions spanning four volts is a pain.
So moving on, can you tackle the real circuit?  That means drawing the voltage and current waveforms and explaining them comprehensively and clearly so that people can understand you.
Yes, but it is still not defined properly. So, accurately, probably not all that accurately.
So, lets see what we can do.
    1: Input Current Source Voltage: 1v
    2: Loop A Inductance: 2 Henrys
    3: Loop B: 1 Henry
    4: Using a 0.1 Ohm Current Sensing Resistor
    5: At t = 2 the Switch, SW1, Opens in the Circuit.
What we want to know:
    Inductor Impedance (This is not the same as Resistance): ZL = 2 pi f L
    Graph the Sensed Current over time.
EMJunkie
Quote from: MarkE on May 04, 2015, 01:23:38 AM
An Electronics Guru, and anyone that has EYEBALLS MarkE will CLEARLY see that this:
    A: Has nothing to do with "Partnered Output Coils" - You driving these Coils with a DC Source, not an induced EMF - You GOON!!!
    B: See that youre In-Capable of getting the Circuit and its parameters correct for at least a few days.
    C: See that youre a Fool
    D: All of the above!!!
Your Failure in providing anything, Circuit Wise, of use, clearly shows your incompetence for at least an entire day!
Frogs aren't Lemons and Cars aren't Igloo's, so best you start putting your Dummy back in your mouth before you, again loose more teeth: On your Bike FOOL!!!
Chris:
<<< What we want to know:
    Inductor Impedance (This is not the same as Resistance): ZL = 2 pi f L  >>>
Where do you see a frequency component to this circuit?  Do you see an AC source anywhere?
Good on you for trying to simulate it.  Assuming you do a successful simulation, you still have to explain what you are seeing.  You also have to pull in a MOSFET model to do it properly.  Can't your simulator allow you to drop a virtual probe anywhere?   You don't need to use a 0.1 ohm resistor if that's the case.
EMJunkie
MarkE's utter brilliance and concise illusion to delusion and lack of teeth is just too much!!!!
I cant believe the lack of real applied concepts he implies here! What a total GOOSE!!!
MarkE, you're put me into amazement! I cant understand how you could POSSIBLY compare the two circuits/Concepts - Is there a Brain Malfunction with you? Oh that's right you're still waiting for one! MileHigh CLEARY Stated there was no Mutual Inductance, is the first problem!!!
Next thing we will hear, is that All electric Energy comes from MarkE's Hot Air!
Youre Fully Retarded - A brain dead Retard = MarkE
