Void
LOL! :D
MarkE, I know very well about the potential for measurement error... I mentioned it in my comment...
It's interesting that some other claimed over unity devices also sometimes mention
that a lowering of temperature was observed. I believe that was mentioned for the Floyd Sweet device for example,
if I recall correctly.
EMJunkie
Guys,
Really, anyone with the most infinitesimal spec of common-sense surely could not argue: X to run a Circuit/Machine that produces X + Y is Overunity!
A Hydraulic Ram Pump is COP = Infinity - I have to put no Input in to the System!
This simply cant be argued! Not by any sane mind!
   Chris
EMJunkie
This is how it is - Period!!! - Simply!!!
   1: Partnered Output Coils (Two Output Coils) configured such that the Magnetic Field's (Lenz's Law EMF = -dPhi/dt) Oppose each other!
   2: A cost effective way to excite the Coils - Input
   3: Some patience and perseverance!
These three things will give you Over Unity! If you properly follow these three rules, it will happen eventually! If you cant grasp and complete these three tasks then you should not be here!!!
No amount of debate or petty manipulations via fancy misconceptions or out right LIES will ever change this! It will always hold true in to the ages...
   Chris
picowatt
Quote from: EMJunkie on May 15, 2015, 04:55:59 PM
http://en.wikipedia.org/wiki/Hydraulic_ram
A typical energy efficiency is 60%, but up to 80% is possible. This should not be confused with the volumetric efficiency, which relates the volume of water delivered to total water taken from the source. The portion of water available at the delivery pipe will be reduced by the ratio of the delivery head to the supply head. Thus if the source is 2 meters above the ram and the water is lifted to 10 meters above the ram, only 20% of the supplied water can be available, the other 80% being spilled via the waste valve. These ratios assume 100% energy efficiency. Actual water delivered will be further reduced by the energy efficiency factor. In the above example, if the energy efficiency is 70%, the water delivered will be 70% of 20%, i.e. 14%. Assuming a 2 to one supply head to delivery head ratio and 70% efficiency, the delivered water would be 70% of 50%, i.e. 35%. Very high ratios of delivery to supply head usually result in lowered energy efficiency. Suppliers of rams often provide tables giving expected volume ratios based on actual tests
EMJunkie
Quote from: picowatt on May 15, 2015, 06:52:07 PM
Picowatt - I think you may be confused here?
You're quoting Efficiencies....
I used the Term COP - Coefficient of Performance.
Are you trying to prove some sort of point?
The fact remains, the Hydraulic Ram Pump, once started, does not require any Input from You or Me, once started, it runs itself!!! This is a COP = Infinity!!! If you are disputing this, please explain!
   Chris
