0 Members and 27 Guests are viewing this topic.
picowatt
Quote from: EMJunkie on May 15, 2015, 06:56:45 PM
Picowatt - I think you may be confused here?
You're quoting Efficiencies....
I used the Term COP - Coefficient of Performance.
Are you trying to prove some sort of point?
The fact remains, the Hydraulic Ram Pump, once started, does not require any Input from You or Me, once started, it runs itself!!! This is a COP = Infinity!!! If you are disputing this, please explain!
   Chris
Less energy is output in the form of the increased head at lower flow than must be input to the system via the input head and flow rate.
Although this may be "free" energy if one has an unlimited source of water at a given head, I would consider a ram pump to be a COP of much less than one.  Ram pumps produce a lot of waste water and are, overall, quite lossy.
A "COP=Infinity" would, to me, indicate that self looping would be possible, which clearly is not possible with a lossy and inefficient ram pump
Although hydro plants, solar, or wind generators may be considered "free energy" in some sense as they utilize a freely available source of energy, I would not consider them "overunity" or having a "COP=infinity".
QuoteThe device uses the water hammer effect to develop pressure that allows a portion of the input water that powers the pump to be lifted to a point higher than where the water originally started.
It's a boost converter!  It's a switching power supply - mechanical version.  Powered by a fusion reactor.
You have to know how to read in between the lines.
Brought to you by the biggest free lunch in the sky - the Universe!
picowatt
Quote from: MileHigh on May 15, 2015, 07:18:12 PM
I can already see the Kickstarter for "fusion powered" water pump kits.
EMJunkie
Quote from: picowatt on May 15, 2015, 07:10:34 PM
Picowatt - COP = Q/W
Where:
   Q = Energy Supplied
   W = Work Done
In our case, we are only considering the Work we have to put into the System. Which is Zero
Example:
COP = 1/0 = Infinity
I am sure all here would be very happy with any System that runs itself!!!
Do you pay for the Magnetic Field after the Magnet has been manufactured? No!
View this how you will.
EMJunkie
MileHigh, I find this post rather Arrogant? Did you intent it this way?
Surely the entire point of being present here in this forum is to find ways to Power our Electrical Appliances via the cheapest possible ways? Preferably Free of Cost to Us, the End User!
I don't see what the problem is here?
Why is this fact so hard for you guys?
