0 Members and 64 Guests are viewing this topic.
Quote from: EMJunkie on May 18, 2015, 02:24:02 AM
Hahahaha - nice try!!!
Generated, synthesized waves don't count!!!
Try making a real device that works!!!
Hahaha - I can feel your frustration OOZING!!!
What's the matter, you and your sock puppets are falling behind! I'm making videos of things that DO ACTUALLY WORK faster than you can leave your cowardly "Thumbs Downs" on them!
The only things you feel OOZING are your own dribbles of false claims without support, poor measurements, and ignorance of your own chosen topic.
Quote from: EMJunkie on May 18, 2015, 02:25:44 AM
Keep it up TinselKoala, you're showing all here how important this really is!!!
It's just as important as you are making it: false claims without support, failure to comprehend your own test equipment, years of your life wasted chasing something you can't even articulate properly. You're so messed up now that you're afraid to show anything of your "work" at all, since you are beginning to realize what a crock it all is.
Quote from: MarkE on May 18, 2015, 01:33:22 AM
The calculator returns the value:  Watts W: = Voltage V: * Current I: * cos(Phase Angle theta).
The calculator returns correct values for cases of a pure sine wave where: Voltage V is rms Volts, Current I is rms Amperes, and Phase Angle theta is the phase angle between the voltage and the current.
EMJ's ideas is worse for where?  Everywhere.
Certainly the Calculator does what it is told to do. And anyone can do the calculation with the calculators that come with their computer's operating system without needing to download anything. But as you point out.... the validity of the output in Watts depends on correct parameters of the input values. If the "current" and the "voltage" are taken from different branches of the circuit as EMJ has demonstrated, or if DC offset is neglected by improper use of the test equipment as EMJ has demonstrated, or if any of a myriad of other circumstances obtain... the output result validity is the same as that of the input: Garbage IN, Garbage OUT.   QED.
EMJunkie
Well Done Mark, you're so totally brilliant!!! Can you detent my Cynicism?
EMJunkie
Quote from: TinselKoala on May 18, 2015, 02:37:49 AM
Hahaha - Good try.
I see youre really cut up about the Thumbs down thing!!! Are you going to be ok?
I can assure you, 1: I don't have the time to go sign up 9 YouTube accounts and vote you down, 2: I don't have the need or want to do such a thing.
I suggest you call YouTube and get an audit done to see what happened there.
You will have received the thumb's up Notification I did give you for one of your videos. But if you still want to believe it was me, then hey, have fun with that!!! Will you be Ok?
Hahaha TK, just a little bit of a Zap up the Jaxie and you wouldn't be a bad bloke you know - Hahaha
