0 Members and 121 Guests are viewing this topic.
MarkE
Quote from: EMJunkie on May 18, 2015, 02:24:02 AM
Hahahaha - nice try!!!
Generated, synthesized waves don't count!!!
Try making a real device that works!!!
Hahaha - I can feel your frustration OOZING!!!
Where is your "real device that works"?  By your own admission, your measurement set-ups were wrong.
EMJunkie
Quote from: TinselKoala on May 18, 2015, 02:40:28 AM
It's just as important as you are making it: false claims without support, failure to comprehend your own test equipment, years of your life wasted chasing something you can't even articulate properly. You're so messed up now that you're afraid to show anything of your "work" at all, since you are beginning to realize what a crock it all is.
Claim as you wish, I will keep showing things that you just cant get near on the bench, soon all will know who the False Claimant is!
Not at all, I do exactly that, I show my work, as I have something I feel I would like to share, I share. I could easily show the device and even do a video and show you, but like I said, there is no point showing devices that are sometimes geometrically quite different from the last as it would just confuse you...
I can assure you, Bill Alek's SPT does work as he stated, all the other devices before him that used the same concepts all worked as stated, Paul Raymond Jensen, Floyd Sweet, and many many more...
Just between these few devices, you can see some similarity's but also some differences...
TK, it's surely got to be time old mate! Time to open those peepers, wake from your long lived sleep, start to think just a little outside the box!!!
I have given you all the answers, you just have to put them together!!!
MarkE
Quote from: TinselKoala on May 18, 2015, 02:47:38 AM
Certainly the Calculator does what it is told to do. And anyone can do the calculation with the calculators that come with their computer's operating system without needing to download anything. But as you point out.... the validity of the output in Watts depends on correct parameters of the input values. If the "current" and the "voltage" are taken from different branches of the circuit as EMJ has demonstrated, or if DC offset is neglected by improper use of the test equipment as EMJ has demonstrated, or if any of a myriad of other circumstances obtain... the output result validity is the same as that of the input: Garbage IN, Garbage OUT.   QED.
I have no dispute with any of that.  I only wished to point out, and it seems that you agree, that for appropriately narrow circumstances, EMJ's trivial calculator does generate correct results.  Those narrow circumstances do not include any of the waveforms that I recall EMJ posting.  And worse, as you and many others have noted: EMJ did not take his voltage measurements across the circuit branches that he took his current measurements from.
MarkE
Quote from: EMJunkie on May 18, 2015, 03:19:29 AM
You have firmly established yourself as that.
LOL, you show your work even when you don't show your work.  That's rich.
Then your assurances are false, because Bill Alek's leaky transformer does not generate surplus energy.  It never has, and it never will.
The similarities all revolve around people making free energy claims who also happen to show poor skills at making accurate AC power measurements.
That is much what Stuart Campbell says about the useless wet bag of hammers being sold by Rosch/Gaia.  You can of course attempt to make and present experiment measurements that will support your claims.
EMJunkie
Hahahaha - Hang on a minute, did we just recently have a picture of you holding your calculator to get a simple answer of 1 + 1 x 0 + 1 = ?
But this is Ok? You criticise me, for eliminating more potential errors than you would be subject to on your beautifully Sharp Calculator?
Hahaha Keep it up TK, These are the words of a bitter old man tired in his continued search - Failure is the result of this behaviour... You need to think positive!!!
I don't need my equipment to tell me what I have re-discovered, I use my equipment the way I was taught to use it. Any possible error as absolutely miniscule it may be, is insignificant to the Output...
Your best quality is criticising others, and you are blind to all, yourself, I wonder if this has a Name?
