EMJunkie
Quote from: MarkE on May 18, 2015, 03:53:54 AM
It is really something that you continue to post a quote to Mr. Duell that no one can establish he ever said so that you can disparage him by calling him a "dick head".  This is a malicious act that you keep repeating by personal choice.  It really makes a sad statement about you.  Do you suffer some malady that has prevented you from maturing into a functional adult?
Google Image Search, guess what Rank this Image gets???
Hahahaha - You Fool!!!
MarkE
Quote from: EMJunkie on May 18, 2015, 03:41:37 AM
Keep kidding yourself Duell!!!
This is where your efforts at offensive behavior turn into absurd comedy.  You associate me with an esteemed and revered man in hopes that it is an insult.  But the only thing you can come up with is an alleged quote that has been discredited for decades.  You cannot come up with an attribution for the quote, because it is extremely unlikely that Mr. Duell ever said such a thing.  This has all been explained to you before with references.  So, in your efforts to disparage Mr. Duell and me:  You tell outright lies, and demonstrate that you are happy to tell those lies for the purpose of falsely disparaging the revered Mr. Duell.  Is this the way adults around you behave?  Is this the kind of behavior that adults around you encourage?  Are there any adults around you?
EMJunkie
Quote from: MarkE on May 18, 2015, 04:05:29 AM
If one waveform is supposed to be the voltage across a branch, and the other is supposed to be the current through that same branch, then the reactive power is only about 36% of the real power.  You need a much bigger reactance.  Then you can match that with its complement and build a tank circuit.
Well Done MarkE!!! A sensible Post!!! Ok I will take this into account.
EMJunkie
Ok, MarkE, TK and others here, maybe we can discuss the Input power and what this means when such a large Phase angle is seen?
This is Reactive Power, typically Phase angles would only be seen from 0 Degrees to 90 Degrees and normally not beyond 90 Degrees.
Calculated Power RMS is -9.03 Watts...
These watts are returning back to the Source..
How much Power is lost, How much Power is used, what power ratios can we expect from the Input Reactance, MarkE mentioned 36%
Come on guys, lets get serious! Lets get into this!
MarkE
Quote from: EMJunkie on May 18, 2015, 04:15:22 AM
Since you trust Google perhaps you will avail yourself to using it to research the opinions that he actually expressed.  For example:  https://books.google.com/books?id=VMcpAAAAYAAJ&pg=PA28&dq=charles+h+duell+invented&hl=en&ei=row8TfrUG9T1gAfP4sDTCA&sa=X&oi=book_result&ct=book-preview-link#v=onepage&q&f=false
The quotes from Mr. Duell are diametrically opposed to the unattributed quote that you use as an excuse to disparage him.  Whereas we have from one Chris Sykes the dead wrong insistance that an oscilloscope must be set to AC coupling in order to properly measure AC signals.  This one Chris Sykes insisted on this point even when his error was repeatedly pointed out to him.  What does one call a person who not only pretends to have expertise but also demonstrates they don't know what they are talking about and resist learning?
QuoteHi PIH123,
Quote from: PIH123 on January 21, 2015, 10:42:59 PM
    So for anyone testing this, apparently, you should see no difference whether your scope is AC or DC coupled.
No - This is not what I said! Please Re-Read the post.
It depends on the setup. If the Output is AC then AC is needed on the scope. Vice Versa...
    In which case, best testing practice would say make sure it is DC coupled on both channels so you won't miss anything unexpected.
No, again I disagree!
"In alternating current (AC), the flow of electric charge periodically reverses direction." - A H-Bridge can Chop the DC and the flow of electric charge periodically reverses direction.
Ref: http://en.wikipedia.org/wiki/Alternating_current
This is just common-sense, so please don't try to confuse others here!
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
No one has to invent quotes and falsely attribute them to you in order to disparage your reputation.  Your actual quotes do that.  The one above is less than four months old.
