tinman
Quote from: Leely on May 21, 2015, 07:53:19 AM
What is happening here people?
Not much by the look's.
Im waiting for the !!free energy!! part of this thread to show it's face ;D
How ever,i have just finished casting a toroid transformer setup i wish to try. The big difference here is that i have two sets of windings cast into the center of the core itself-->thats right,the windings are part of the core. The plan is then to wind a single power wire around the outside of the toroid as the conductor that carries the current to produce the magnetic field in the core. If the magnetic field is contained within the core as most say,then when the internal windings are loaded,there should be no BEMF seen at the outer power winding-->no reflection shown at the primary. ;D. As i assume this wont be the case,at least i can see what is happening at the center of the toroid core when current is flowing through the outer winding. Maybe the center is out of phase to that of the outer winding-->maybe the current flowing through the inner windings is totally opposite to that of the outer winding-180* out of phase. Who knows,but it's always been something i wanted to try.
Leely
Quote from: tinman on May 21, 2015, 08:41:03 AM
How ever,i have just finished casting a toroid transformer setup i wish to try. The big difference here is that i have two sets of windings cast into the center of the core itself-->thats right,the windings are part of the core. The plan is then to wind a single power wire around the outside of the toroid as the conductor that carries the current to produce the magnetic field in the core. If the magnetic field is contained within the core as most say,then when the internal windings are loaded,there should be no BEMF seen at the outer power winding-->no reflection shown at the primary...
Talking about transformer that has no reflection check this inductive/capacitive transformer
forest
Lots of stupid talk  >:( Can't we work together to solve problem ?  :-[
Leely
forest
There is only one problem : how to setup transformer to force situation when primary does not see secondary load change.
