0 Members and 101 Guests are viewing this topic.
MarkE
Quote from: EMJunkie on May 29, 2015, 12:08:48 AM
PW, I don't disagree, and there is nothing wrong with using a Sense Resistor as a method of checking against Probe measurements. But like I said, a sense resistor introduces a new set of problems.
In saying this, a Probe that is used, as long as it is within its recommended ranges, is still a better method of measuring than a sense resistor! See, you used the word "can" which means youre attempting to cast doubt, and also expecting User Error. Like I pointed out before:
   Chris Sykes
       hyiq.org
Once again you demonstrate your ignorance.
picowatt
Quote from: EMJunkie on May 29, 2015, 12:52:31 AM
Hahahaha I was waiting for it... Insinuation the Claim carry on...
Google: EMJunkie Sine Wave site:http://overunity.com/15395/partnered-output-coils-free-energy
You're going to be surprised by the result!
   Chris Sykes
       hyiq.org
Apparently I was recalling your experiment 1 an 2 in the PDF of your first post, as well as your second video in that same post, wherein you did not use sine waves.
I have no idea what you mean by  "Insinuation the Claim carry on...".  Is this related to your COP 1.7 claim?
And yes, I believe the word "can" was used appropriately...
EMJunkie
Quote from: picowatt on May 29, 2015, 03:21:19 AM
PW, good, I am glad we have now finally cleared this up. Are we good to carry on now?
For others reading, they may not be aware or have not read...
Re "experiment 1 an 2" - If you wish, you can view the experiments as were presented in this document: "Guidelines to Bucking Coils" - The reader will see that the provided experiments have nothing to do with the technology I am trying to present and are merely a learning tool to assess the Coil Characteristics under certain conditions.
Re "the second Video": Solid State Generator - How to Build and tune a Solid State Electrical Generator!!! - Low Level OU - Published on Nov 2, 2014 - Note: this video is nearly three years old now.
PLEASE READ ME!!!
***** For All: http://www.hyiq.org/Downloads/Guidelines%20to%20Bucking%20Coils.pdf - Perhaps one of my most important works. Its still a work in progress. Check back regularly as this document could change at any time.
This video is nearly 2 Years old and I have decided to release this as a how to for others. I have been telling people about this technology for years now and many people just don't get it!!!
This is simply, Charge Separation. Its a Lenz Law reduced, or No Lenz Law Electrical Generator. Thus, as Paul Raymond Jensen describes and I have re-discovered from my own research and investigations over the years.
Turns Ratio on the output must be more than on the input! I have 2: 1 turns Ratio. Floyd Sweet used 5:1 and Paul Raymond Jensen used 3:1 turns Ratio.
Don't be a DUMMY! Learn this now before it's too late!!!
It's simple once understood, but maybe it is just too hard for many people!!! Especially those that don't want to understand!!!
This video relates to:
1: https://www.youtube.com/watch?v=iJsVSMQqCOM
2: http://www.hyiq.org/Research/Details?Name=A%20Free-Energy%20Device
3: http://www.hyiq.org/Updates/Update?Name=Update%2011-02-14
These Quotations from Tom Bearden:
"Now to some specific issues:  Yes, my insight did keep growing.  At first I took the results of experiments such as by Hooper, with opposing "ordinary waves".  The effects of the core for the coils were a puzzle, but it seemed that sometimes the "opposing normal waves" would give some G effects, and more often they would not.  What I did not realize for some time was that the longitudinal wave can be regarded as a superposed wave/antiwave, via a single SWZ wavepair.  This agreed with Whittaker, and also now offered a sudden inspiration as to when we got the G effect and when not.
We were dealing with four waves, not two, in the opposing ordinary waves.  We had two opposing normal waves and two opposing antiwaves, with the wave/antiwave coupling.  Two ordinary waves 180 degrees out of phase would certainly cancel (spatially) their amplitudes (as is well-known in RAM materials and structures) but would not cancel their energies.  The two antiwaves would do likewise, spatially.  The point then became, so what would happen in the time domain?  Here we got a shocker.  The two antiwaves would cancel each other's amplitude SPATIALLY, and would add energies.  But looking at the action (energy x time) aspect, their energies exist in negative time!
Well, this meant that the antiwave ACTION would come out negative, and would then cancel the added positive wave ACTION because ? Ewt + ? Eaw(-t) = 0. Therefore the sum of the whole mess was zero!  Bummer!  We wound up with everything just vanishing, wherein all the action (angular momentum) seemed to vanish.  Well, this showed that the notion of simply having waves 180 degrees out of phase of itself would not give gravity effects.  So that's why mostly the Hooper approach didn't seem to do much.  But if one added nonlinear materials to the core, then one broke the linear cancellation. Once in a while, if one got it just right, one could get some spooky gravitational effects.  So that was a real clue."
Ref: http://www.cheniere.org/correspondence/072796.htm
"( 6 ) Investigative experiments to explore bucking EM force fields which neatly zero sum would have almost immediately revealed highly anomalous behavior of materials and circuits. [Such simple investigations of zero-vector EM force field summation do not seem to appear in the Western literature at all, so far as can yet be established.]***
***with the single exception of the Aharonov-Bohm effect, which has finally been proved after 27 years of controversy, and Hooper's work which was obscurely published.
Something very much like that, together with quantum mechanical ideas, would have had to be applied to explain the operation of the Moray device. Note that every one of the suppositions above was available to any thorough Soviet search—and the Soviet scientists certainly made the search, more massively and thoroughly than has ever been done before or since. Since the evidence is overwhelming that the Soviet scientists developed electrogravitation and scalar EM weapons, it seems logical that their search succeeded along these lines or similarly."
Ref: http://www.cheniere.org/books/analysis/history.htm
"I'd also like to point out the patents and work of Hooper. Hooper seems to be the only physicist who ever methodically investigated EM stresses, structuring of those stresses, and the gravitational implications of those stresses in the laboratory."
Ref: http://www.cheniere.org/misc/interview1991.htm
I clearly stated in earlier posts that this video was an old Video I decided to share. The reader can make their minds up for themselves.
If you the reader, want Free Energy, Overunity, COP > 1, then you need to learn and then build this Tech, before its too late. This just could be the absolute last time you get the chance to change the world for the better!
   Chris Sykes
       hyiq.org
MarkE
Overunity, COP > 1 is something that you have yet to demonstrate that you can do.
EMJunkie
Quote from: MarkE on May 29, 2015, 11:51:34 AM
According to thought processes of the Asleep Conventional Mind, so have these people:
Inventors
Alphabetical Listing
A
◾[Adams, Harold] - Engine (similar to that of Keely)
◾[Adams, Robert] (New Zeland) - Adams Motor
◾[Alexander, Robert] - Generator With Free energy
◾[Adsitt, Donald] - Magnetic Ramp
◾[Ames, Alan] - Alcon Technologies Devices
◾[Amman, C. Earl] - Cosmo Electric Generator
◾[Angus, Neil] - Angus Engine
◾[Anonyme, Français] - Receiver for extracting Electricity from Air
◾Aspden, Harold (England) - Power From Magnetism, Vacuum Spin, Switched Reluctance Motor
◾[Avrandt, Dick] - Bobines Tesla (reproduction)
B
◾[Bailey, Patrick] - Advanced Fuel Cell Designs
◾[Barret, Terrance] -Tesla Non-Linear Shuttle Circuit
◾[Baumann, Paul] (Switzerland) - Swiss ML Converter ou Testatika
◾[Baumgartner, William] - Living Machine turbine
◾Bedini, John - Bedini Energy Converter
◾[Bessler, Johann Ernest Elias dit ''Orffyreus''] - Perpetual Wheel
◾[Billings, Rodger] - Battery with hydrogen laser
◾[Blasius-Grüter, Karl] - Self current Gravitation torque converter
◾[Blue, Archie] - Apparatus With Electrolysis
◾[Bode, George, Fred] - Electric Motor utilizing Electricity from permanent magnets
◾[Bohning, P.] (Germany) - Engine without rétrocouple
◾[Bolon, William] - Engine vapor high performances
◾Bauman, Paul -
◾Bowman, Lee - Engine of Peregrinus (reproduction)
◾[Britt, Robert Gordon] - Noble Gas Motors (AEROPS Engine)
◾[Britten, Chauncey, J.] - Radio Apparatus Extracting Energy from the Air
◾Brown, Paul - Brown Resonance Device (Brevet US), Magnetic Distributor Generator
◾Brown, Thomas Townsend - Parallel universe, antigravity, T.T. Brown Devices
◾[Brown, Yull] - Brown's Gas
◾[Brunner, Ashton F. Mochel] - Ocean Wave Generator
◾[Buerger, Douglas] - SpinBreeder Generator
◾[Butikofer, Hermann] (Switzerland) -Calorific generator
C
◾[Camus, Nelson] - Turbo battery NELTRON
◾[Caro, Charles R.] - E-Beam Discharge Power Converter
◾[Carr, Otis] - Carr Anti Gravity Device
◾[Chambrin, Jean] (France) - Water Engine
◾[CINCINNATI GROUP] (Neal et Gleeson) - LENT-1
◾[Clem, Richard] - Clem Over Unity Engine
◾[Cobb, Melvin] - Energy Conserver Circuit
◾[Coler, Hans] (Germany) - Magnetstromapparat, Stromerzeuger
◾[Cornish, François P.] - Generator -.hydrogen and aluminum
◾[Correa, Paulo et Alexandra] - Autogenous Pulsed Glow Discharge
◾[Cottel, Eric] - Sonic transformer for fuel with water
◾Cowlishaw, David E. -
◾Directory:Wes Crosiar, aka John Stout
◾[Crump, Lloyd R.] - Energy Extractor
D
◾[Davis, Barry] - Davis Tidal Turbine
◾[De Rivas, Villasnor] - Electromagnetic Generator
◾[Deavenport, Larry] - T.T. Brown Devices Replication
◾dePalma Bruce - N-Machine
◾[Diggs, Richard] - Engine With Liquid Electricity
◾[Directo, R.F.] - Field generator (CAOROP projects)
◾[Dorman, Robert] - L.I.A.G. Low Inertia Armature Generator
◾[Dragone, Leon R.] - Permanent Magnet Energy Conversion
E
◾[Earle] -Windmill Home generator (Earle)
◾[Ecklin, John V.] - Ecklin Motor
◾[Egel, Geoff] (Australia) - Testatika (reproduction)
◾[Estevel, Edward] - Engine with hydrogen extracts
◾Fauble, James D. - Ion Source Beam Projector
F
◾[Farnsworth/Trombly] - Farnsworth/Trombly Energy Generator
◾[Finsrud, Reidar] (Norway) - Finsrud Motion machine
◾[Fischer] -Moteur à Chaleur
◾[Fogal, Bill] - Fogal
◾[Fox, Hal] - Cold Fusion Results
◾Francoeur, Alan - ALF Vaporizer; Dynamo, Frenette , Mechanical Heater (Patent #4143639)
◾Frank, Andrew A. - Father of the modern Plugin Hybrid Electric Vehicle (PHEV)
G
◾[Gamgee, John] - Zeromotor with sea water making ammonia boil
◾[Gary, Wesley W.] - Gary's Magnetic Motor (1879)
◾[Geiger, Josef Otto, Hartmann et Ziegfeld] - Rotary magnet Engine-generator
Featured: Organizations / Inventors >
Best Kept Secret: Geoffrey S. Miller's Energybat Labs - His projects include: cold electricity; crystal batteries; centrifugal energy amplification; Tesla experiments, including a Tesla turbine; magnetic rail; Bedini energizer; Enerybat alternator; Newman magnet motor; Searl motor; Hull's fusion; Joule ringer; Energybat household 10kW generator; and the Energybat rotating solenoid motor. (PESWiki; August 12, 2013)
◾[Graham, Roy] -
◾[Graham] -
◾[Graneau, Peter] - Ampere-Neuman Electrodynamics
◾Gray, Edwin V. - Capacitive Discharge Motor
◾[Griggs, James L.] - Hydrosonic Pump
◾[Grotz, Toby] - Russell Optical Dynamo Generator
◾[Gunnerman, Rudolph] - A-55 carburant mixte à 55 % d'eau
H
◾Hammel, David - Generator antigravitational with Free energy
◾James Hartman -
◾[Hartmann, Stefan] (voir) - PM Square Linear Magnet Motor
◾Josef -
◾[Hattaway, George] (Canada) - Unipolar Dynamo
◾[Hendershot, Lester] - Hendershot Coil Device
◾[Henthron, Wayne] - Automobile ''électromatique''
◾[Herrmann, Robert] - Moteur Stirling et chaudière
◾[Hickox, Barbara] - Dynamo électrique
◾[Hooper, William] - Motional Electric Field Effect
◾[Hubbard, Alfred] - Hubbard Coil Motor
◾[Hubbard, Alfred] - Hubbard Coil Research
◾[Hull, Richard] - Bobines Tesla Coil Builders of Richmond TCBOR
◾Hutchison, John - Crystal Energy Converter
◾[Hyde, William] - Hyde Device
I
◾[Ide, Osamu] - Capacitive Discharge Motor
◾[Inomata, Shiuji] (Japan) - N-Machine
J
◾[Jamison, Lawrence] - Jamison Energizer System
◾[Jefimenko, Oleg] - Jefimenko Electrostatic Free Energy Generators
◾[Jensen, Paul Raymond] - Series Resonant LC Circuit, Unidirectional Transformer
◾Johnson, Howard - Permanent Magnet Motor
K
◾[Kawai, Teruo] - Kawai Motor
◾Keely, John Ernst Worrell - Keely Motor (Hydro - Vacuo Engine)
◾Kanarev, Ph. M. (professor) - Redefining physics, with energy ramifications
◾[Kenyon, Keith E.] - Economic engine electric car
◾[Kidd, Sandy] - Kidd Device
◾[Kieninger] - N-Machine
◾[Klemke, Erich E.] (Germany) - Autonomous electric generator
◾Konzen, Doug -
◾Kron, Gabriel - arguably the greatest electrical scientist ever produced by the United States
◾[Kromrey, Raymond] - Kromrey Converter
◾[Kunel] - (Germany) Electromagnetic generator
L
◾[Lambertson, Wingate] - WIN Device
◾[Leach, Sam Leslie] - Generator separating hydrogen/oxygen
◾LeBreton, Robert P. -
◾Dennis Lee -
◾[Leibowitz, Martin N.] - MNL-DHE Generator
M
◾[MacNeill, Ken] - Proposed Hubbard Coil Motor
◾[MacNeill, Ken] - Reluctance Generator
◾Mallove, Eugene - Cold Fusion
◾Marinov, Stefan (Autriche) - Siberian Coliu, Venetin Coliu
◾[Mark, Stephen] - Stevens Generator
◾[Markovitch, Peter] - Apparatus to rectify Ether Energy
◾[Marks, Alvin] - Electric generator
◾[May, Ed] - Converter on Buick Wildcat
◾Mazzilli, Paolo
◾[McClain, Joel] - Magnetic Resonance Amplifier (MRA)
◾[McKie, Richard (Scott) et John] - McKie Power On Demand Module (PODMOD)
◾[McClintock, David] - Air Engine
◾[McKubre, Michael] - SRI Experimental Research Results
◾[Melnitchenko, Andrew A.] - Effect projector of resonance
◾[Merritt, Thomas D] - Electrical Generator
◾[Meyer, Stanley] - Water Fuel Cell
◾[Minato, Kohei] - Minato Magnetic Motor
◾Moray, T. Henry - Moray Radiant Energy Equipment
◾Muller, William (Bill) J. F. - Muller Magnetic Motor
◾[Mundt, Jurgen] - Electric generator Transducer of Waste
◾[Murray, Jim] - Torque amplifier Gravitational apparatus
◾[Myers, Roy J.] - Apparatus collecting ambient electricity
N
◾[Naudin, Jean-Louis] (France) - Newman's Machine (reproduction.)
◾[Nègre, Guy] (France) - Air engine
◾Newman, Joseph - Newman Energy Machine
◾[Nichelson, Oliver] - Dynamo Unipolar according to Tesla
O
◾[O. Gerald- (MAGNETICENERGY) Ro-Mag Magnetic Generator
P
◾[Pacheco, Francisco] - Générateur à hydrogène
◾[Pantone, Paul] - Generating group Engine with plasma (GEET)
◾Papp, Joseph - Noble Gas Motors (Papp engine)
◾[Papadopoulos, Konstantinos] - Permanent magnet generator
◾[Pappas, Panos] - Energy From Electrical Discharges
◾[Patterson, James] - Patterson Power Cell
◾Paramahansa Tevari -
◾[Perkins] - Patent# 44245797 Mechanical Heater
◾[Perreault, Bruce A.] - Radiant Energy Capture Device
◾[Perrigo, Joeseph ou Harry] - Magnito generator
◾[Podkletnov, Eugene] (Finland) - Podkletnov Device
◾[Pond, Dale et Keely, John E. W.] - Musical Dynasphere Globe Motor
◾[Pons et Fleischman (France) - Pons and Fleischmann Status
◾[Potter, David] - Adams type Motor
◾Potter, Paul E. -
◾[Prenninger, Johann] - Testatika (reproduction)
◾[Puthoff, Hal] - Charge Cluster Technology (CCT)
Q
R
◾Randell, Dr. L. -
◾[Rauch, H.] - Static Quantum Generator
◾[Reed, Troy] - Reed Magnetic Motor
◾[Reich, Wilhelm] - Orgone Energy Phenomena, Reich Orgone Motor
◾[Richardson, William H.] - Aqua Fuel
◾[Rodin, Marcos] - Rodin Coil Research
◾[RQM' (Suisse) - RQM Devices
S
◾[Schaeffer, Bernhard] - Converter of heat into mechanical energy
◾Schauberger, Victor - Schauberger Vortex Effects
◾Searl, John (England) -Searl Generator, Searl Levitation Device
◾[Seike, Schinichi] (Japan) - Landau Oscillator Seike
◾[Serogodsky, Albert Victorovitch] -Thermal instrument
◾[Sinclaire, Pierre] (Canada) - Gravity Magnetic Device, Sinclaire Generator
◾[Smith, Wilbert B.] - Geomagnetic Generator; Magnetic Sink
◾[Smith] - Nuclear Decay Effects Experiments (Smith)
◾[Sorgato, Vittorio] - Moteur à Air
◾[Spence, Geoffrey M.] - Energy Conversion System
◾[Stephens, William] - Stephens Motor
◾[Stevens] - Apparatus with electricity of field E.M of the ground
◾[Stoneburg, William G.] - Stoneburg Motor Generator
◾Storms, Edmund - Los Alamos Experimental Research Results
◾[Sullivan, Steven] - Omnificient Dynamo
◾[Sweet, Floyd] - Sweet Vacuum triode Amplifier (VTA)
T
◾[Takahashi, Yasunori] - (Japan) Takahashi Magnet Motor
◾[Tate, John] - Tate Ambient Power Module
◾[Taylor, Robert] - MRA Device S/N 95-3
◾[Teal, Bob] - Magnepulsion Motor
◾[T.E.B.A.Tesla Engine Builders Association] - Turbines Tesla (reproduction)
◾[TEKKO KURE] (Japan) - Moteur ''Wankel'' Magnétique
◾[Tesla, Nikola] - Non-Linear Shuttle Circuit
◾[Tewari, Paramahansa] - (India) N-Machine
◾[Thermacore Co.] - Thermacore Cold fusion
◾[Trombly, Adam et Kahn, Joseph] - N-Machine (Trombly-Kahn)
◾[Troyan, Joseph P.] - Amplifying Troyan engine of movement
◾[Turner, Brent] - Bobines Tesla Techno. Research (reproduction)
Many more also! History just keeps recording more and more people! But, alas, the Asleep Conventional Mind will never grasp such a Simple Device! For I have made Energy Easy for the waking minds! Your choices are yours, free will and common-sense will prevail.
   Chris Sykes
       hyiq.org
