0 Members and 45 Guests are viewing this topic.
MarkE
Quote from: EMJunkie on June 09, 2015, 09:27:19 PM
I am going to give you all a BIG CLUE!
Your Input must be used effectively! - To excite the Coils, to get a Current Flow in the Partnered Output Coils!!!
Once a Current Flow's in the Partnered Output Coils the Partnered Output Coils become a Solid State Electrical "Generator" - This is Charge Pumping!!! At its most efficient!
Remember, I have shown you, time and time again, it is TWO Opposing Magnetic Field Interactions that vary over time, that Separates Charge!
   Chris Sykes
       hyiq.org
1-1 = 0 even for very large values of 1.
EMJunkie
Quote from: MarkE on June 09, 2015, 11:31:09 PM
When the Input, MarkE, = 0 or very close to it, and the output is > 0 then one has to wonder: "Maybe Chris is really trying to give us something that is more than special!!!"
I know you can see this already, but you play the Innocent Rule player because you must have been told off as a student!
The mind set imposed: "Listen, don't ask questions, the Laws I tell you are set in Stone"...
Why?
I am the other way, challenge everything! Listen and Learn but accept no failure, Engineer everything!
   Chris Sykes
       hyiq.org
MarkE
Quote from: EMJunkie on June 09, 2015, 11:59:39 PM
You have failed to establish that 1 - 1 <> 0 for any values of 1, large or small.  You are welcome to keep trying all you like.
Why?
Because the "Laws" have strong evidence that support them, and you have offered no evidence against them.  You have shown that you have problems taking and checking measurements:  GIGO.
   Chris Sykes
       hyiq.org
Failing to properly set-up, take, and check measurements is not engineering.  It is just garbage experimentation.
EMJunkie
Quote from: MarkE on June 10, 2015, 12:12:51 AM
You have failed to establish that 1 - 1 <> 0 for any values of 1, large or small.  You are welcome to keep trying all you like.Because the "Laws" have strong evidence that support them, and you have offered no evidence against them.  You have shown that you have problems taking and checking measurements:  GIGO.Failing to properly set-up, take, and check measurements is not engineering.  It is just garbage experimentation.
Again MarkE, all your belief's and Assumptions not ever provable on your part!
I have never given you any Measurements!
I have never given you anything but Solid Science, backed up by Experiment, that shows the same result every time.
But Assume all you like! I find it Funny!
   Chris Sykes
       hyiq.org
P.S: Assuming I am negating, modifying, or implying anything to any of the "Laws" of science that is not simply Engineering them for use, to do work, is merely speculation on your part.
That's all I am doing, I am USING the "Law's" of Science for practical use, to perform Work!
In other words, applying practical Engineering to the very same "Law's" you refuse to Challenge!
EMJunkie
Call me a Lenz's Law Engineer!
   Chris Sykes
       hyiq.org
