0 Members and 47 Guests are viewing this topic.
EMJunkie
Quote from: FatBird on January 17, 2015, 07:44:36 PM
EMJunkie, Can you please post the circuit that you said is too complicated for beginners.
Thanks.
@FatBird
Some Pictures as promised:
I started a thread: My Cerberus Code. My code is a bit more advanced that this now.
@ALL - Please don't let this discourage You! It does not need to be this complicated, Time Consuming, or expensive!
Quote from: EMJunkie on January 16, 2015, 07:44:44 PM
EBAY: http://www.ebay.com.au/itm/Dual-H-Bridge-DC-Stepper-Motor-Drive-Controller-Board-Module-Arduino-L298N-BY-/200991688684?pt=AU_B_I_Electrical_Test_Equipment&hash=item2ecc09c7ec
or
EBAY: http://www.ebay.com.au/itm/43A-H-Bridge-Drive-PWM-For-Arduino-Semiconductor-BTS7960B-Stepper-Motor-Driver-/380802365419?pt=AU_B_I_Electrical_Test_Equipment&hash=item58a996f7eb
Look at the frequency range before purchasing. Anything from 50Hz to 5KHz will do the trick.
Quote from: EMJunkie on January 17, 2015, 05:10:47 PM
Maybe this: EBAY: http://www.ebay.com.au/itm/180W-180W-2CH-12V-Small-Stereo-High-Power-Amplifier-for-CD-MP3-Car-Audio-Home-/400586923881?pt=AU_Electronics_Audio_Amplifiers&hash=item5d44d75f69
I actually bought the small Amplifier as I thought it was really well priced for the unit!!! The above is cheap and if the Frequency's are suitable, these are more than sufficient to start with.
For anyone that has read the pdf and studied in detail, some may see that these devices can be Uni-Polar and also Bi-Polar. This is something I will go into later on as I don't want to complicate the technology at the beginning. It is best to start with and for others wanting to take measurements, to start with Bi-Polar Devices.
Again, You don't need to go to this trouble! I have spent way too much Time and Money on this Project!
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
Jeg
Hi Emjunkie
Thanks a lot for sharing this interesting work of you!
Is it possible pls to explain with few words what exactly is the A vector and its relation to the e-field which apparently is being doubled after the cancellation of the H-fields?
Thanks
hanon
Quote from: EMJunkie on January 18, 2015, 03:21:52 PM
@Hanon
No, it doesn't work like this!
Bucking Coils are only used on the Output!
Not on the Input!
Hi Cris,
I know that the bucking coils are used on the output. My scheme is about two bucking coils used to collect the induced current. Please revise it again. Forget about the two inducer coils orientation. I just used two inducer coils because I think that each inducer coil will influence one induced coil and therefore the result could be better. Please have a look again. Think about the inducer magnetic field and the induced fields of the whole system. Thanks.
I do not know if you are aware of Garry Stanley anti-lenz coil. He used two bucking coils as your proposal but into a rotary device. Here I add a link in case you want to investigate this:  http://www.energeticforum.com/renewable-energy/5911-garry-stanley-pulse-motor-2.html
EMJunkie
Quote from: Jeg on January 18, 2015, 06:00:29 PM
Hi Emjunkie
Thanks
Hi Jeg,
The A Vector Potential is the Electric Component of a Magnetic Field. Thus the reason we use the term Electromagnetic Field.
Sir Richard Feynman best describes the A Vector Potential, I have attached the pdf.
Kind Regards
EMJunkie
Quote from: hanon on January 18, 2015, 06:18:09 PM
Hi Chris,
Hi Hanon,
What you have shown is not what I am trying to get across to people! None of the principals I have shown are incorporated in your schematic!
In my work:
1: Step Up techniques must be incorporated!
2: Input Coil must be single standard wound coil.
3: Loose Coupling is best used to see the effects.
No way for an increase in Energy is possible in this schematic.
I am sorry, I have to be blunt here simply because I don't want anyone to get confused. I am going out of my way to try to help. I really am short on time as I have so much stuff on right now!
Kind Regards
