0 Members and 82 Guests are viewing this topic.
a.king21
Quote from: NickZ on June 21, 2015, 05:35:39 PM
     a.King:
     You may have touched on the partial answer my question, as to WHY we don't GET IT.
    Mind control!!!  Airborn devices, satellite woodpecker signals, Tv commercials, Cell phone, etz...
    Microwave interference, altering the mind's ability to conceive certain ideas,
such as FE concepts,  etz...    So, we are not free to invent, nor re-invent,  at all.
        NickZ
Exactly that. One of us should build the device and aim it back.
woopy
Hi Tinman
interesting  day in testing and learning around my motor
Just for info ( i precise because i know that i have to be very careful if i don't want to be shot down by ...)
I used the right part of your circuit schematic for the generating operation, and tried many things as differents  caps value and bulbs. Each of my stator generator coils is 1.9 ohms and about 16 mH. The 6 volts rated incandescent bulb light not at full brightness and the scope rms value across the cap and bulb indicates 4.6 volts.
So, for a first estimation concerning the left part of the schematic, i decided to use a easy way to get a shorting circuit on the second coil. So i mounted a small neomag on the shaft of the motor, and i connected the 2 end leads of the coil to a reed switch, so i could test the shorting all around the 360 degrees, by slowly moving the reed switch all around the shaft and magnet. So far this method seems not good and the shorting with the reed switch decrease slightly the brightness of the bulb and i did not get any sweet spot where the output increase. So i have to think otherwise i presume.
Voila , not very scientific, but my simple practical progress in this experiment.
Tomorrow is an other day, keep calm.
laurent
NickZ
    Nelson:
   I will watch the video again,  looking for the meter readings dropping, when the bulb is connected.
   I hope that you're right, about this.
   But, the main thing is to be able to feed-back some of the "extra power", and obtain a self runner. Or not?
   EDIT:
   Although it's not a partnered coil set up, (my older video below) there may be some similarities,  with my version of the
Akula/Ruslan device.   4 minute mart is showing what I mean with regards to the bulbs and impedence matching.
  But, with higher output, and higher bulb lumin levels, the fets to get hotter, as well.  So, it a tricky balancing act.
   https://www.youtube.com/watch?v=o8wcekZP8vU
nelsonrochaa
Quote from: NickZ on June 21, 2015, 05:47:11 PM
    Nelson:
Hi Nick ,  the output where  bulb is connected is a Bemf output and when is "consumed" the motor speed raise and the amp lower.
Try to see this to understand the context of circuit .
https://www.youtube.com/watch?v=bY3Mr2pAErw
About a self runner machine , is not a concern for me for now :) i work to find first  others aspects like improvements in conversion of power to real work available,  with small  inputs and with minimal losses.
But maybe in future . I like start a by the floor not bye the roof ;)
Thanks Nick for your comment i appreciate your work in kapanadze theme , thanks for share
Quote from: woopy on June 21, 2015, 05:46:37 PM
Hi Tinman
laurent
No Woopy, I resent being called the bad guy for pushing Tinman to try to do better.  Tinman has issues with refusing to accept information that he doesn't believe is right.  It has to be "pushed and forced" into him over and over.  He also has issues where he can't admit that he made a mistake and it just becomes silly.  He can't simply say, "I admit that I made a mistake, thank you for correcting me."  His presentation of his information is fair to poor to very poor, and he doesn't believe in any kind of professional courtesy with respect to providing complete information and summarizing his data for his audience.  So for me it's too frustrating to deal with him.  Nor is Tinman any kind of special person that is above criticism.
So I am not "shooting down" Tinman and I am not a "bad guy."  I think my pushing him and making demands of him are and were reasonable.  Reasonable demands, not crazy demands.  I don't have the patience that Mark or PW have and I don't believe that people should always "bend over ass-backwards" to "compensate" for Tinman's deficiencies.  I have watched many big, long, hard, grinding debates over weeks and weeks between Tinman and experts like Mark and PW where after all that time it turns out that Tinman was completely wrong.  It shouldn't be so difficult.
I am no angel, and Tinman is certainly no angel either.  Clearly, I am not the person to engage with Timnan on his projects and I should stay away.
Beyond that, I will simply repeat that he does not have any free energy technology with this setup.  He has been through this loop many times in the past and in the end there is always some reason for the misunderstanding.  Like I said, coil shorting is not a source of free energy.  It would appear that Tinman believes that it is, because that is the key component in his setup.  I don't know if it will take days or several weeks to finally arrive at the proper conclusion.  But in the end the truth will come out.
Yes, I pushed him in a way that he did not like and sometimes people need a push like that.  I was not "shooting him down" I was demanding petter performance from him and he is clearly refusing to try to do that.  I am not the bad guy.
MileHIgh
