0 Members and 113 Guests are viewing this topic.
EMJunkie
After all, Denying the Blatantly Obvious, is, after all, simply, a Lie!!!
   Chris Sykes
       hyiq.org
tinman
Quote from: synchro1 on June 26, 2015, 02:56:16 PM
Quote from Tinman;
"Coil B's current can flow into the cap along with coil A's current for a brief period of time, but coil A's current cannot flow into coil B at any point".
My Lenz Reversal theory is based on JLN's "Core Lag" theory. What happens to Coil "A" core's "Remnant Viscosity" when the Coil B current reverses it's polarity, and Coil B's core demagnetizes? Does the Bucking connection briefly neutralize the core polarity?
Tinman's not the first to retard the dwell by discharging into an output coil. Lengthening the "Hysterisis Loop" by inducing impedance.
QuoteThe circuit schematic clearly shows the path for Coil B's current into the cap traveling through Coil A. Coil B is connected to the cap through Coil A.
I guess you dont see the blocking diode on coil A,and the position of the connecting wires of coil B.
QuoteHow could it be possible to charge Coil A from Coil B if they weren't connected? The B Coil "Charge Event" of output Coil A may make a crucial difference in the Transformer's performance.
That is because coil A is not charged from coil B.
I will make this simple for you. Get your self a bucket that will hold water-this will be your cap.
Now get two garden hoses that are connected to two different taps-tap A and tap B. Turn both taps on so water is flowing out of each hose,and into the bucket.
Question 1-Is the water from tap B flowing through tap A before it is collected in the bucket?
2-Can the water from both tap A and tap B flow into the bucket at the same time without flowing through each other first?
Now lets put a T piece in the hose coming from tap A,and we will connect the hose from tap B into that T piece,so as now the water from both tap A and tap B will flow through the same hose to get to the bucket.
Question 1-If tap A is turned off(the blocking diode),can the water from tap B flow through tap A to get to the bucket?
2-If water is flowing from tap A and tap B,will the water from tap B flow through tap A before it gets to the bucket?,or will the water flowing from tap B turn in the direction of flowing water from tap A at the T piece,and flow into the bucket along with the water from tap A?.
Contrary to belief,rocket science really is very simple.
tinman
Quote from: woopy on June 26, 2015, 05:15:11 PM
Hi Tinman
just a question
Is the flyback spike the result of the collapsing field of the rotor coil, when the brushes are passing  from one segment of the commutator to another,
or  should it  be possible that the process creating  the flyback spike is able to tap in the environment's energy to CREATE A NEW MAGNETIC FIELD[/b] ?
Laurent
The environment dose not have to create any new magnetic field,as it already exist within the core.
tinman
Quote from: EMJunkie on June 26, 2015, 09:08:39 PM
   Chris Sykes
       hyiq.org
Quote@MarkE - Seems Tinman even thinks your way of thinking is FUBAR!!!
And where or how did you come up with that?
We both agree that a higher energy state can be achieved from a lower energy state,but weather or not that higher energy state can do more useful work than was used to create it is yet to be seen.<-- this is in reference to my gas/two tank combo experiment in the !open systems! thread.
QuoteHow about just admitting that you are wrong and cant comprehend it? Its just TOO Hard for your little mind to grasp!!!
The best thing to do EMJ to show MarkE he is wrong,is to show him your system working in an OU mode.
EMJunkie
Ok - New Poll - Please vote as you see fit or post your definition below!!!
Results from the last posted below:
   Chris Sykes
       hyiq.org
