0 Members and 92 Guests are viewing this topic.
ramset
TinMan
As always   you show How to get things done and not waste time, you use your resources here wisely and with gratitude ...whatever the outcome .
You  and those helping you make good measurements  are a great example of how this thread should Look.
I must add ,I hope the biggest lesson here will add to our knowledge of what is truly possible .
Regardless the outcome you stand head and shoulders above the noise.
Respectfully
Chet
Thanks Grandma
synchro1
@Tinman,
I'm trying to trace the connection from the negative side of the Diode. Would it be fair to say Coil B shorts itself through Coil A? I can't tell how to distinguish the "Closed Switch" configuration from the "Bucking Coil" loop.
Normally a diode needs the negative side connected to a ground to conduct current, but if the voltage from Coil B exceeds the Cap charge, the diode may send it through Coil A.
I think both Coils may contribute to deliver the overall "Torque".
woopy
Hi tinman
i understand very well that you want to be sure that your  "out of the box" results have to be be accepted by.....  ME and ......PW and even ...........MH or on the top by .99 , to reassure you of what you seem to get ??
So far i see at this time, and thank's to your measurement donation , it seems that ME is happy with your measurement process .
And my question is, what is your intention next,
Will you try to patent the hided "concerning element "
Or will you disclose openly and without any problem your invention to all of us so we can replicate ?
Laurent
EMJunkie
Quote from: ramset on June 27, 2015, 10:27:05 AM
TinMan
Respectfully
Chet
Chet, maybe You could crowd fund Tinman, do something useful for those that can work without all the Limitations of the World on them! Open to real things that are possible when ones mind is not closed!
Tinman, need a new Rigol, new FG, new Car?
   Chris Sykes
       hyiq.org
Quote from: EMJunkie on June 27, 2015, 05:54:12 PM
   Chris Sykes
       hyiq.org
I take issue with how you are funding yourself.  I see you have apparently hooked up with some dude in Argentina and you are selling pixie dust video downloads.  When I did some digging on your Spanish friend I found a page where they said he was associated with up to 25 web sites.  I did a partial Google Translate on one other web site associated with him and it looked like some kind of "audio therapy" system for losing weight and stuff like that.
I am holding my nose, tale a look at the next eight pictures:
