0 Members and 40 Guests are viewing this topic.
Farmhand
Quote from: TinselKoala on June 29, 2015, 05:03:20 AM
Thanks, and I am completely serious. It's not exactly "self looping" but it's a valid way of testing devices that produce electrical outputs from electrical inputs yet whose circuitry or arrangements don't permit directly hooking up the out to the in.
During the "outage" I made this post on OUR:
QuoteIt appears that the device is putting out more power than it takes to run it... but it cannot simply be self-looped due to the configuration of the supply and output.
    The solution is very simple. Here is what you do. You make a _second, identical_ device and run it on the output of the first one. Say the device uses 10 watts and produces 12 watts output. (I'm just using those numbers for illustration.) SO you take the first one, connect its output to the input of the second device along with a 2-watt resistive load. The first device taking in 10 watts should be able to run the second device AND the 2-watt additional load, and the second device should put out its full 12 watts.
    Daisy-chain a few identical devices this way, each one running the next one in line PLUS an additional load.... And if the device incorporates a motor, then each extra device in the chain should have its motor running at the same speed or torque as the first one. IF, that is, the devices are really putting out more power than it takes to run them.
    You should be able to chain an indefinite number of devices plus their extra loads, all operating only on the original 10 watts input to the first device.
    Or ... you should be able to come up with some coherent explanation of why this cannot be done, in spite of the "overunity" performance _measurements_ of each individual device.
The only problem I see with that plan is if the output of device number 1 cannot be accurately determined then how can the output of the device number 2 be accurately determined to be 12 watts.
My take is that if the output cannot be measured accurately enough as it is then it is probably measured inaccurately, and the output of any piggybacked device won't be accurately determined either.
I doubt anyone will build a chain of devices to satisfy the crowd here.
The way I see it if the input and output cannot be measured accurately by Brad then he needs to allow someone qualified and with the appropriate equipment to measure the input and output.
I read that Brad has taken down his videos. Does anyone expect to see him on the news with his OU invention ? We should have a survey on that.
MarkE
The advantage of the scheme is that it is a relatively good null test for assumptions of what the input and output power is of the DUT.  If the input power has been undercounted and the output power over counted, then it will be hard to make a string of devices even as short as two appear to work.
a.king21
Quote from: MarkE on June 30, 2015, 10:39:13 PM
If the input power has been correctly calculated and the output power has been correctly calculated
then it will be easy to make a string of devices as short as two to work.
Here we have the difference between optimism and pessimism.
picowatt
Tinman,
If you are still reading here, please consider posting
a short reply just to let us know all is well with you.
Even a smiley face would do...
PW
ATOM1
We love tin man he's a hero ! A real gentleman and inspiration !
ATOM1
